doc555 wrote:How can I relocate the default data folder. I would like to use a different folder to store data and my question is, where can I set the data folder location?
joepal wrote:You can set the environment variable MH_HOME_LOCATION to override the default.
If you set MH_HOME_LOCATION to for example "d:\", then the makehuman dir would be created as "d:\makehuman"
https://superuser.com/questions/284342/ ... r-use-them
joepal wrote:We should probably test it works with all plugins though. I don't think I ever did that with the asset downloader.
Aranuvir wrote:joepal wrote:We should probably test it works with all plugins though. I don't think I ever did that with the asset downloader.
All necessary changes were made in getpath.py. As long as you did not hard code any file path, there shouldn't be a problem...
