New Qt: Is the interface supposed to look different?
Postby Rhynedahll » Mon Dec 03, 2012 6:40 pm
(Since the change to pure Python, I can run the latest svn version without problem.)
I flipped the two flags as per the blog post, but don't see any differnce in the interface.
Does it look exactly the same with Qt?
The Key to Magic: Book One
Rhynedahll
Re: New Qt: Is the interface supposed to look different?
Postby joepal » Mon Dec 03, 2012 7:02 pm
The actual UI change hasn't been started yet, unless I've missed something. Currently the code only uses Qt to make the window and for some image routines, and then pastes the old GL-based UI on top of it.
It'll be a gradual change, but the UI will likely look somewhat different once we start to transfer the actual components to Qt too.
Return to Python scripts
