mflerackers wrote:We bundle only a few files, not an entire python distribution, and surely not the development files. You get them from
http://python.org/download/For more detailed errors you can always look in config.log
I know about that link. I have looked there but have not found any specific development download.
My config.log:
- Code: Select all
ile F:\Makehuman SVN\SConstruct,line 13:
Configure(confdir = .sconf_temp)
scons: Configure: Checking for C library m...
.sconf_temp\conftest_0.c <-
|int
|main() {
|return 0;
cl /Fo.sconf_temp\conftest_0.obj /c .sconf_temp\conftest_0.c -O2 /Iinclude /IC:\Python27\include /IF:\sdl\include /IF:\glew\include /IC:\sdl\include /IC:\glew\include
'cl' is not recognized as an internal or external command,
operable program or batch file.
scons: Configure: no
scons: Configure: Checking for Py_Initialize() in C library python27...
.sconf_temp\conftest_1.c <-
|#ifdef __cplusplus
|extern "C"
|#endif
|char Py_Initialize();
|int
|main() {
| Py_Initialize();
|return 0;
cl /Fo.sconf_temp\conftest_1.obj /c .sconf_temp\conftest_1.c -O2 /Iinclude /IC:\Python27\include /IF:\sdl\include /IF:\glew\include /IC:\sdl\include /IC:\glew\include
joepal wrote:Also, there are a few pointers about windows building here
http://www.makehuman.org/node/193I don't remember downloading anything specific for development headers. Maybe you're missing an environment variable?
I'm following that guide.
If I had an idea which files scons is looking for, I could set the path so that they could be found. PyInitialize() is a function, I think, and if it's present in the regular Windows Python 2.7.3 download, then it's inside some file or other, as I cannot find it.
Python is like Russian to me, so I'm totally in the dark, but I think I should be able to compile MH as long as I can get everything in its proper place.
