Editing of the python script for makehuman
Postby manisha » Mon May 09, 2011 5:18 am
Makehuman is supported by the Python API.When we open makehuman it will directly open the model with some default parameters and simultaneously that corresponding script is shown in the script window and if we change anything then it will be reflected in the script window.
My question is "What I want is exactly reverse :idea: ,means Is it possible to make a model by writing the script and to see the corresponding figure in the makehuman window :?: "
Please help me with this.
Thanks,
Manisha.
manisha
Re: Editing of the python script for makehuman
Postby nchandol » Mon Aug 01, 2011 5:13 pm
i would also like to know if there is the possibility to make that a. i mean i know you can import mh, but is possible to make a python script that you can use it to select the characteristics of the model and when running this script making it possible to view your model in the Makehuman Interface?
nchandol
Postby nchandol » Mon Aug 01, 2011 5:14 pm
if mannish you have found a solution for your problem can yu please email it to me cause you will save me a lot of trouble,
Thanx everybody in advance :)
nchandol
Return to Python scripts
