Lack in MC
Lack in MC
Postby Marco_105 » Sat Jan 14, 2017 5:20 am
Makeclothes script doesn't put normalTexture in .mhmat file (when exist in BL materials) but instead puts a textureBump which is not exactly same things :mrgreen:
Could you correct it ?
Marco_105
Re: Lack in MC
Postby RobBaer » Sat Jan 14, 2017 8:21 am
I have added this to the issue tracker
http://bugtracker.makehumancommunity.org/issues/1100
Re: Lack in MC
Postby Marco_105 » Sat Jan 14, 2017 3:35 pm
I made the corrective in my own script for normal map in and it work fine may I bring it somewhere ?
Marco_105
Re: Lack in MC
Postby RobBaer » Sat Jan 14, 2017 3:58 pm
Well, if you are programming savvy, you could issue a pull request at: https://bitbucket.org/MakeHuman/makehuman
Otherwise, if its small enough, you could perhaps attach it here. This would be useful as we look into this issue, and could speed getting changes integrated into development versions.
Re: Lack in MC
Postby Marco_105 » Sat Jan 14, 2017 5:08 pm
I bring the code there, but you have just to find and implement the line with comment:
# some change is there **********
def writeMaterialFile(fp, mat, name, outdir):
    Write a material (.mhmat) file in the output folder.
    Also copies all textures to the output folder
    fp.write(
        '# MakeHuman Material definition\n' +
        '\n' +
        'name %sMaterial\n' % name +
        '\n' +
        '// Color shading attributes\n'
        'diffuseColor  %.4g %.4g %.4g\n' % tuple(mat.diffuse_intensity * mat.diffuse_color) +
        'specularColor  %.4g %.4g %.4g\n' % tuple(mat.specular_intensity * mat.specular_color) +
        'shininess %.4g\n' % max(0, min(mat.specular_hardness/255, 1)) +
        'opacity %.4g\n' % mat.alpha +
        '\n' +
        '// Textures and properties\n')
    useDiffuse = useSpecular = useBump = useNormal = useDisplacement = "false"
    for slotNo,mtex in enumerate(mat.texture_slots):
        if mtex is None or not mat.use_textures[slotNo]:
            continue
        tex = mtex.texture
        if (tex.type != 'IMAGE' or
            tex.image is None):
            continue
        if tex.image.filepath == "":
            raise MHError("Texture %s image must be saved first" % tex.name)
        srcpath = tex.image.filepath
        texpath = os.path.basename(srcpath).replace(" ","_")
        if mtex.use_map_color_diffuse:
            fp.write('diffuseTexture %s\n' % texpath)
            useDiffuse = "true"
        if mtex.use_map_alpha:
            useAlpha = "true"
        if mtex.use_map_specular:
            fp.write('specularTexture %s\n' % texpath)
            useSpecular = "true"
        #some change is there **********
        if mtex.use_map_normal:
            if tex.use_normal_map:
                fp.write('normalmapTexture %s\n' % texpath)
                useNormal = "true"
            else:
                fp.write('bumpTexture %s\n' % texpath)
                useBump = "true"
        if mtex.use_map_displacement:
            fp.write('displacementTexture %s\n' % texpath)
            useDisplacement = "true"
        trgpath = os.path.join(outdir, texpath)
        print("Copy texture %s => %s" % (srcpath, trgpath))
        try:
            shutil.copy(srcpath, trgpath)
        except FileNotFoundError:
            addWarning("Texture\n \"%s\" \nnot found\n" % srcpath)
Marco_105
Re: Lack in MC
Postby Marco_105 » Sat Jan 14, 2017 6:50 pm
MC script don't write the ambientColor line in the .mhmat so simple color from BL look not contrasted in MH.
This works fine for me:
    fp.write(
        '\n' +
        '\n' +
        'ambientColor 0.1000 0.1000 0.1000' +
        '\n' +
Marco_105
Return to Python scripts
