Saving entire models
Postby Shedeki » Fri Dec 09, 2016 12:45 pm
'7_scripting' offers the function 'saveObj()' which -- as its name implies -- saves the current human to an obj file. Unfortunately, it only saves the base (body) mesh together with its material, whereas the GUI's export functionality also saves eyes, teeth, hair, and whatnot. How would you go about achieving something similar in an automatized matter?
Specifically, I want a complete human exported and then import and render it with Blender.
Shedeki
Re: Saving entire models
Postby loki1950 » Fri Dec 09, 2016 6:35 pm
Are you trying to use just the cmd line for your export for use in a script or are you just wanting to get the model into blender in that case nhx2 is the best exporter as it has been customised for blender allowing proper materials for both blender render and cycles render.
Postby Shedeki » Mon Dec 12, 2016 4:45 pm
loki1950 wrote:Are you trying to use just the cmd line for your export for use in a script [...]
Not sure how the command line factors in, but I need to export the model as the last step of a script that I run via the scripting interface (i.e. I hit the button labeled "execute").
loki1950 wrote:[...] get the model into blender in that case nhx2 is the best exporter as it has been customised for blender allowing proper materials for both blender render and cycles render.
That sounds terrific -- I thought I would have to use a script in Blender to correct the materials. How would nhx2 be accessible from a script?
Shedeki
Postby loki1950 » Mon Dec 12, 2016 5:21 pm
Mhx2 is a plug-in exporter it writes a .json file that the gets imported by the blender importer it is not officially part of MH have a look at our mhx2 sub-forum for the details on where to get it and how to install,it should be callable from your script.
Postby Shedeki » Mon Dec 12, 2016 6:27 pm
For reference, this is where mhx2 can currently be found:
https://bitbucket.org/Diffeomorphic/mhx ... n-exchange
I could not figure out how to call the exporter from a script, though. :cry:
Shedeki
Postby drewbeasty » Sat Aug 19, 2017 9:22 pm
I have over 800 morph targets to export. MHScript is ideal for me because it allows me to export all of my custom meshes at once while i sit on couch. Theirs a problem! MHScript.saveObj('Morph Name') only saves base mesh and not the extras that I have applied to my save file mesh MHScript.loadModel('BaseHuman'). I know there is a simple fix for this. I'm new to python and so far it is awesome. But I was wondering have you found a workaround yet for this issue. i really need my eyebrows and hair etc because my mesh look otherwise...naked. In the 7_scripting.py on line 579-583
def saveObj(self, name, path = mh.getPath('exports')):
        log.message("SCRIPT: saveObj(" + name + "," + path + ")")
        filename = os.path.join(path,name + ".obj")
        import wavefront
        wavefront.writeObjFile(filename, self.human.mesh
I feel like if "self.human.mesh" was something else like "self.human.allmesh" or something. Is any one familiar with this at all. Like I said im new to python and im having trouble figuring out how python is accessing these functions. For example like the import mh or import humanmodifier I think i have looked every were but can find these files to use as reference. I figure the must be pre-compiled inside the .pyd files maybe. Any help in the right direction would be greatly appreciated. Thank you.
drewbeasty
Postby Aranuvir » Sun Aug 20, 2017 11:31 am
Just some observations, though I haven't really played around with this part of code.
If you intend to do scripting at all, it could be helpful to get to know greater parts of the code, so either download MakeHuman source code from bitbucket (P2) or github (P3) and get an IDE of your choice (I'd recommend PyCharm Community Edition) with code inspection functionality. (Though, recently it has become difficult to get all dependencies needed to run from source (= PyQT4), best choice is a Linux platform.)
In your example self.human is defined as:
from core import G
self.human = G.app.selectedHuman
You can use MakeHuman's built-in data inspection (tab utilities/data) to see what selectedHuman consists of. If you take a look a 9_export_collada/mh2obj.py you can see that selectedHuman provides a method called getObjects, from there you can pull the meshes and so on ...
objects = self.human.getObjects(excludeZeroFaceObjs=Ture/False)
And then:
meshes = [o.meshes for o in objects]
It might be helpful to take a look at apps/guiexport.py and shared/wavefront.py, too.
The method writeObjFile from wavefront.py has a glitch in P3, the line
if isinstance(path, file):
should be replaced by something like
if isinstance(path, io.IOBase):
or
if hasattr(path, 'write'):
if not the check is superfluous at all. Fixing this in my branch ...
Postby drewbeasty » Fri Aug 25, 2017 11:54 pm
Will pycharm download dependency automatically on linux?
drewbeasty
Postby loki1950 » Sat Aug 26, 2017 1:57 am
drewbeasty wrote:Will pycharm download dependency automatically on linux?
That's a yes if you install it through your distro's package management system that's Apt-get on Debian based ones Yum with fedora,Yast on OpenSUCE or pac-man on BSD based systems if not check pycharm's web site for the deps and you may have to them install the manually. For A Python IDE like Ninja.
Postby drewbeasty » Sun Aug 27, 2017 4:03 pm
Success! My first time using Linux(Ubuntu) now I understand why so many ppl use it, very powerful and light weight. Thanks to @Aranuvir @loki1950 for support, Cant wait to use the py3 port of makhuman.
drewbeasty
Return to Python scripts
Users browsing this forum: MSN [Bot] and 1 guest
