Undefined global names
Postby Shedeki » Mon Dec 05, 2016 11:23 am
MakeHuman seems to handle scopes in some way I cannot get my head around. Take the following script:
import random
def foo():
   print(random.uniform(0.0, 1.0))
foo()
Usually, when interpreted by Python, this script prints some number between zero and one. In MakeHuman, it produces the following error:
Crappy script
The script produced an exception: global name 'random' is not defined
Within the definition of foo, random appears to be unknown. How come? A similar problem can be observed when calling one's own functions within functions.
I am running MakeHuman v1.1.0 on Ubuntu 16.04.
Shedeki
Re: Undefined global names
Postby joepal » Mon Dec 05, 2016 12:09 pm
Ok, first: Just to be clear, this seems to be a script written in the script editor, not python code in makehuman as such.
The scripts piped via the 7_scripting plugin are somewhat limited in that they are executed via an "exec" (see line 824 in 7_scripting.py). This has certain effects on scope. In particular, you cannot assume that a global variable is immediately available in a local contex without using the "global" keyword. For a longer discussion, see:
http://stackoverflow.com/questions/1250 ... ction-work
Executive summary, your code should probably be written like this instead (not tested) :
def foo():
    import random
foo()
Or possibly
import random
def foo():
    global random
foo()
However, the scripting plugin is mostly intended for short, simplistic things. If you want more complex program logic, you'd benefit from implementing it as a plugin instead.
As a side-note, MHAPI (see https://github.com/makehumancommunity/c ... /README.md) is intended to replace 7_scripting in the longer run, by making it easier to write plugins. But some things from 7_scripting aren't yet implemented in MHAPI.
Postby Shedeki » Mon Dec 05, 2016 4:30 pm
joepal wrote:Ok, first: Just to be clear, this seems to be a script written in the script editor, not python code in makehuman as such.
Correct.
joepal wrote:The scripts piped via the 7_scripting plugin are somewhat limited in that they are executed via an "exec" (see line 824 in 7_scripting.py). This has certain effects on scope. In particular, you cannot assume that a global variable is immediately available in a local contex without using the "global" keyword.
Thank you for the explanation. I was expecting something like that, and knowing for certain I'll be able to structure future code differently from the get go.
joepal wrote:
def foo():
    import random
foo()
Yes, that is how I ended up running my scripts.
joepal wrote:However, the scripting plugin is mostly intended for short, simplistic things. If you want more complex program logic, you'd benefit from implementing it as a plugin instead.
Alright -- I'll take your advice and try and look into plugins soon.
I appreciate the quick response.
Shedeki
Return to Python scripts
