Export a model into various poses using command line
Postby xrd » Wed Oct 12, 2016 12:44 am
I've read the FAQ but doing think this is covered.
What I want to do:
* Create a model with the right hair, facial expressions, etc.
* From the command line, export that model as OBJ to various poses (the poses defined in the UI).
Basically, I'd like to get a set of models in various poses.
I'm not sure if there is a generic scripting interface like this. It seems the Python API is for plugins, no?
xrd
Re: Export a model into various poses using command line
Postby RobBaer » Wed Oct 12, 2016 2:52 am
xrd wrote:I've read the FAQ but doing think this is covered.
What I want to do:
You can do this kind of thing with Utilities > Scripting panel in the GUI. The script can be run with utilities > execute. This is only a crude implementation with minimal documentation, but maybe you can make it work for your needs.
Postby joepal » Wed Oct 12, 2016 5:14 am
There is also a skeleton outline for a set of command line utilities in the community-plugins repository:
https://github.com/makehumancommunity/community-plugins
Return to Python scripts
