What I want to do is to generate and to obtain the model for use in my custom program (.net).
I will pass my parameters to makehuman,and then makehuman generate the model.How can I do that?
Thank you in advance!
joepal wrote:MH isn't built for this. It's primarily a GUI application.
This said, the easiest way is probably to make a plugin that starts a socket server, and then speak with that from your third part application.
joepal wrote:You have access to the whole internal makehuman API if you write a plugin.
http://www.makehumancommunity.org/api/
