Running MakeHuman from source
Postby joepal » Sun Aug 30, 2015 9:01 am
If you are reading this forum, you will most likely benefit from running MakeHuman from source rather than downloading a "build".
The steps for doing so are summarized here: http://www.makehumancommunity.org/wiki/ ... e_clone%3F
The API documentation is currently available at http://www.makehumancommunity.org/api
Re: Running MakeHuman from source
Postby make3 » Sun Dec 16, 2018 7:20 pm
hello,
Do you think its possible to put all the Python stuff into the same folder ?
make3
Postby wolgade » Fri May 10, 2019 10:30 am
As I was tricked by this thread, not realizing that Joel's initial posting is rather old:
If you're looking for the source code of MH 1.2, you'll go to https://github.com/makehumancommunity/makehuman. This page also contains instructions on how to get started.
Return to Python scripts
