dependencies and their versions
Postby shuang0120 » Sun Aug 30, 2015 1:04 am
Hello:
I want to run makehuman directly from a source download, what dependencies and their versions should I install beforehand? Are they numpy, pyQt (Riverbank), pyOpenGL and OpenGL? I used Windows7 64 bit, Python 2.7 and PyCharm Community Edition 4.5.3. Appreciate. I'm in urgent need of help,thanks.
shuang0120
Re: dependencies and their versions
Postby joepal » Sun Aug 30, 2015 8:26 am
First, the hard limitations are these:
* You must run python 2.7, 3.x won't work
* You must run QT4, QT5 won't work. Thus you need to match PyQt with this
* You will in all likelyhood need to run 32-bit versions of all dependencies, even on a 64-bit system. This because at least one dependency does not exist in 64-bit version, and you can't mix bittiness. This might have changed though, it was a while since this was checked.
Giving these limitations, you should be able to pick the latest matching version of all dependencies.
If you're uninterested in researching versions on your own and don't mind deps which are half a year old, there's a zip file with all that's needed here: http://files.jwp.se/makehuman.html
This is known to be working, although you might have to install a microsoft VC redist package if one of the deps complain about missing DLL packages (there's a readme in the zip).
Postby RobBaer » Tue Sep 01, 2015 2:41 am
On Windows, the dependencies can be conveniently installed as a single bundle by installing WinPython:
http://sourceforge.net/projects/winpyth ... ython_2.7/
I have used the 64-bit bundle successfully (ver. 2.7.9.2) for some time with the nightly build. The bundle includes pyQT and numpy along with the Python. It's been a great experience using it!
Postby joepal » Tue Sep 01, 2015 6:18 am
RobBaer wrote:On Windows, the dependencies can be conveniently installed as a single bundle by installing WinPython:
Cute. I absolutely did not know that.
Postby shuang0120 » Tue Sep 01, 2015 7:47 am
joepal wrote:First, the hard limitations are these:
After installing these dependencies, I can successfully run those codes. :D :D, thanks a lot!!!! But there still exists a problem. I'm a student. Because of the need of research,I need to learn the makeHuman code now. In the MH, we can drag the slider to regulate model's gender, height, weight and so on. Dose there are special algorithms to control these changes? I wonder where these codes exist and I want to track these codes. I want to understand the principle of morphing. Can you help me? Thank you in advance.
shuang0120
Postby duststorm » Tue Sep 01, 2015 12:00 pm
Have a look at the files lib/targets.py, apps/humanmodifier.py, core/algos3d.py and apps/human.py
I have done my best to include a good amount of code documentation in there, that should set you on your way.
Postby shuang0120 » Wed Sep 02, 2015 2:52 am
duststorm wrote:Have a look at the files lib/targets.py, apps/humanmodifier.py, core/algos3d.py and apps/human.py
Thank you for your reply. :D :lol: .With your help, now I can successfully track the code. I am so happy and excited :lol:.
shuang0120
Postby Aranuvir » Fri Sep 04, 2015 6:37 pm
@RobBear: I added the WinPython-link to the BitBucket_Wiki and I have just two questions. Is installing WinPython enough, or do you need further configuration? Can we rely on the 64bit version?
Postby shuang0120 » Wed Sep 16, 2015 2:23 am
Now I have run the code for a period of time, but I still have some questions that I can't figure them out. I am new to Python, so I want to get some help from the forum. Thank you in advance!
How and where should I start the debug process about the dragging the slider to control the morphing? I have no idea so I start the process of debug from the makehuman.py. When run the app/human.py, I find some code related with core/events3d.py.
 gender = min(max(gender, 0.0), 1.0)
        if self.gender == gender:
            return
        self.gender = gender
        self._setGenderVals()
        self.callEvent('onChanging', events3d.HumanEvent(self, 'gender'))
class HumanEvent(Event):
    def __init__(self, human, change):
        self.human = human
        self.change = change
    def __repr__(self):
        return 'event: %s, %s' % (self.human, self.change)
But I don't understand the link between the two pieces of code. What should I do to track the human.py code to HumanEvent code? Thanks in advance!
shuang0120
Postby duststorm » Fri Oct 16, 2015 10:03 am
The code that is invoked by the slider is in lib/modifierslider.py, see the various variants of onChange and onChanging.
apps/humanmodifier.py:
ModifierAction.do() is what is executed once a slider is dragged and released, it's an undo-able action.
modifier.setValue() performs a complete update of the human, modifier.updateValue() allows selective updates.
In the end human.applyAllTargets() is responsible of updating the human.
The humanEvents are not for updating the human, they are emitted by the human when it is edited to inform other plugins of this event.
If you are interested in debugging the event propagation, there is a separate logger where event debug messages go to. It's disabled by default as it generates a lot of noise, but you can modify the logging config to enable event debugging.
Return to Python scripts
