issue #23
issue #23
Postby joepal » Wed Mar 10, 2010 9:43 am
I've been thinking about finally fixing issue 23:
http://code.google.com/p/makehuman/issues/detail?id=23
However, there are three ways one could do that, and I'd like input on which to go for before submitting anything.
The first approach is adding this line in the top of __init__() in main.py
os.chdir(os.path[0])
Which is a quick and easy solution, but which changes the working directory. This might have unforeseen consequences if we ever want to use the makehuman binary for command line stuff like piping.
The second approach is to modify all data loading lines so that for example:
self.scene3d.selectedHuman.setTexture("data/textures/texture.tif")
becomes
self.scene3d.selectedHuman.setTexture(os.path[0] + "/data/textures/texture.tif")
Unfortunately, bug #23 is present in every single location where anything is loaded. It is everywhere simply assumed that working directory is the one containing the makehuman binary. Thus this'd lead to many, many code changes.
A third, slightly more beautiful approach would be to modify all file access methods in all classes so they properly take into account what the working directory is and compensate for it. Then the previous example would be:
self.scene3d.selectedHuman.setTexture("texture.tif")
.. and inside setTexture(), the file would be prepended with os.path[0] + "/data/textures/". This approach would require some planning and also probably many code changes. It might also lead to unforeseen consequences if one forgets to change stuff somewhere.
In any which way, I'm currently favoring the first approach since it'd be a minimal code intervention.
Comments?
Re: issue #23
Postby joepal » Tue Mar 16, 2010 4:22 pm
I changed my mind. I think this should end up in main.c instead.
Proposed patch:
52a53,55
> /* for dirname() */
> #include <libgen.h>
565a569,579
> // start change to solve issue #23
> char *dirc, *basec, *bname, *dname;
> char *path = argv[0];
> dirc = strdup(path);
> basec = strdup(path);
> dname = dirname(dirc);
> bname = basename(basec);
> printf("dirname=%s, basename=%s\n", dname, bname);
> chdir(dname);
> // end change for issue #23
Please review before I commit, since I'm kind of noob on C programming. :)
Re: issue #23
Postby mflerackers » Wed Mar 17, 2010 9:30 am
Actually we have an API to get a folder depending on the OS, getPath. We just need to add additional folders to this method. It's planned, but I didn't have time for it yet. It's better than using the current folder, as on unix you might want to put the data separate from the executable. We also need to think of application and user folders for the same content, as some users on the same system might have their own choice of plugins, or some might use additional morph packages.
MakeHuman project Developer
mflerackers
Re: issue #23
Postby joepal » Wed Mar 17, 2010 10:04 am
Is that a python API or a C api? Right now, main.c crashes since it tries to execute main.py in current folder, so that's before python has started at all. I think the same actually happens on windows, at least if trying to launch from "run" or from a command prompt using absolute path.
Re: issue #23
Postby mflerackers » Wed Mar 17, 2010 10:10 am
The method can be used from python as well as from C. Unfortunately there are still many places where we should use it instead of hardcoded paths.
mflerackers
Return to Python scripts
