when import the mh,error with "ImportError: DLL load failed"
Re: when import the mh,error with "ImportError: DLL load failed"
Postby gsnake » Wed Feb 17, 2010 9:22 am
How to define the makehuman_as_module ?
does use the command :
gcc -g -Wall -shared -D MAKEHUMAN_AS_MODULE -o mh.pyd ./src/main.c ./src/glmodule.c ./src/core.c ./include/core.h ./include/glmodule.h -IF:/Python26/include -IF:/MinGW/include/SDL -I./include -LF:/Python26/libs -lpython26 -lmingw32 -lSDLmain -lSDL -mconsole -lglu32 -lopengl32 -lgdi32 -lmsvcrt -lwinmm?
gsnake
Postby gsnake » Fri Feb 19, 2010 4:22 pm
What is the file format in the command "lpython26 -lmingw32 -lSDLmain -lSDL -mconsole -lglu32 -lopengl32 -lgdi32 -lmsvcrt -lwinmm"?
Does the .dll meet the requirement?
Thanks.
gsnake
Postby mflerackers » Sat Feb 20, 2010 2:10 am
-o mh.pyd : means the output file needs to be called mh.pyd
-shared : means dll
-D MAKEHUMAN_AS_MODULE : should define MAKEHUMAN_AS_MODULE
Did you modify any of the C or H files?
MakeHuman project Developer
mflerackers
Postby gsnake » Sat Feb 20, 2010 1:44 pm
No,I didn't modify any files of the c and H,all stay the same as they are in the svn
mflerackers wrote:-o mh.pyd : means the output file needs to be called mh.pyd
-shared : means dll
gsnake
Return to Python scripts
