Trying to understading MH internal files
Postby aristocrata » Sun Oct 04, 2009 9:06 pm
Can someone tell me about?
I'm trying to understand how works internal MH file system to make a decent MH importer to Blender.
Is Makehuman\data\3dobjs the place where are placed make human meshes?
Is base.OBJ the base mesh?
Are lines beginning with v inside the base.OBJ vertices coordinates?
Are lines beginning with f face vertices? Why it has the format int/int/int?
What means other lines inside base.OBJ?
What means other files and its line contents?
How works MH pose system? Is there a Skeleton/Armature?
aristocrata
Re: Trying to understading MH insernal files
Postby mflerackers » Sun Oct 04, 2009 11:59 pm
The base.obj is just a standard wavefront object file http://www.martinreddy.net/gfx/3d/OBJ.spec, this can be imported into blender by default. When you make modifications in makehuman, these modifications are stored in /models. When you export these changed models, they are exported as a wavefront object file in /exports together with a bvh file containing the skeleton.
MakeHuman project Developer
mflerackers
Return to Python scripts
