State of MakeClothes?
Postby SaltyCowdawg » Tue Dec 10, 2019 9:22 pm
According to the plugin download page MakeClothes is still Alpha. Is this true? I got a bunch of clothes I want to try as I might to make and eventually share to the community.
Re: State of MakeClothes?
Postby Elvaerwyn » Wed Dec 11, 2019 12:49 pm
The makeclothes was completely remade by punk duck you can find it in its existing state on his github, this will be merged soon as we are now in the final bug testing phase I do believe and it looks very very promising.
https://github.com/black-punkduck?tab=repositories
This new tool will be called convertclothes as we are not really making clothes but transferring them to makehuman compatibility mainly. Let us know if you find any bugs there is working versions for 2.79 and 2.8 now.
Please note in rewriting it, the functionality is different now, better in a way and will take a small learning curve to remaster!
Postby SaltyCowdawg » Wed Dec 11, 2019 2:24 pm
Just got a headache trying to walk through the code. :lol:
Postby Elvaerwyn » Wed Dec 11, 2019 3:18 pm
please check your inbox!
Postby SaltyCowdawg » Wed Dec 11, 2019 4:10 pm
Got the gifts... must be Christmas time. :-)
Postby SaltyCowdawg » Wed Dec 11, 2019 4:12 pm
Do you have the 2.8 version? I just tried loading it and Blender complains it needs upgrading to 2.8.
Postby punkduck » Wed Dec 11, 2019 7:53 pm
hi
The normal version we work is the 2.80 version, yes.
So you can load the "master" here:
https://github.com/makehumancommunity/community-plugins-makeclothes
(press "clone or download" and then download zip file)
You can also check, if the branches already have more code, they are normally considered as less stable, but not necessarily.
When you click on branches, you get the different versions, e.g. my own:
https://github.com/makehumancommunity/community-plugins-makeclothes/tree/punkduck_devel
You can also download the files the same way. The 2.79 version is derived from this version at the moment. Since Elv also tested it, it is rather stable already.
Postby joepal » Thu Dec 12, 2019 7:16 am
The nightly builds of the plugins are available here: http://www.makehumancommunity.org/content/plugins.html
The makeclothes 2 download should be of master which (I think) is still blender 2.80 only.
Postby punkduck » Sat Dec 14, 2019 6:13 pm
joepal wrote:The nightly builds of the plugins are available here: http://www.makehumancommunity.org/content/plugins.html
Yes. I only added a method to use the common .config file of MakeHuman (if available) for an alternative data directory and a method to delete all helpers in case you imported your basemesh. Furthermore I added some smaller fixes (not to take a vertex group with < 3 vertices etc.). That's in the punkduck-devel 2.80 branch.
My own 2.79 will always be an alternative for all of those using old Blender including myself. It will not contain "better" code because I merge all changes into this version. I will give that up when nobody (including myself) needs this any longer.
I uploaded the first two assets made with MakeClothes V2.
