Cant Open MakeHuman
Cant Open MakeHuman
Postby DixyDreamscape » Fri Sep 27, 2019 2:51 pm
I have read through everything I can find, but I have not ran across a solution to the problem I am having.
Makehuman seemed to install fine on my windows 10 laptop. But I cant get the program to open, it sits forever on the loading screen then it tells me, Exception During Event onStart.
I have tried reinstalling, I have tried running in a different platform. I have went in and turned of McAfee Virus protection.
The program worked fine on my windows 8 laptop but I had to get a new laptop the old one gave out on me.
Any suggestions will be greatly appreciated.
Thank You Dixy
DixyDreamscape
Re: Cant Open MakeHuman
Postby joepal » Fri Sep 27, 2019 4:00 pm
Postby DixyDreamscape » Fri Sep 27, 2019 4:28 pm
joepal wrote:Did you read http://www.makehumancommunity.org/wiki/ ... _not_start
What does the log say?
No I hadn't found that, It says Unless I want to run it from the source, I cant run it and will have to wait on a new release.
I tried to run it from the source and it says it cant find the path >pip install pyopengl and I really am not sure what to do from here.
If it says it cannot find the command "pip", you will have to specify the full path to it. This should be in the "scripts" dir where you installed python.
So where does python install at? I couldn't find it.
Seems that it is running without installing pip install pyopeng1 because it is working now.
Will let you know if I run into anymore errors thank you for your help.
Dixy
DixyDreamscape
Postby RobBaer » Wed Oct 02, 2019 6:33 am
Can you attach makehuman.log from C:\Users\%USERNAME%\Documents\makehuman\v1py3 ?
Postby Donkeyshvonz » Sat Dec 21, 2019 6:22 am
yup...same behavior here...
details of system:
Intel i5-73000HQ CPU @v 2.5 Ghz
RAM 8 Gb
64 bit OS
Windows 10 home
Nvidia GeForce GTX 1050 Ti
thanks!
Donkeyshvonz
Postby joepal » Sat Dec 21, 2019 10:19 am
Your system should not have any issues related to graphics cards. But without having seen the log (see http://www.makehumancommunity.org/wiki/ ... _report%3F) we can't say what is wrong.
Postby thecreativefool » Mon Dec 23, 2019 4:52 pm
I am having the same problem. I've attached my log file; I'm running Windows 10 with a 64-bit operating system and an i7 processor. Let me know what could be happening.
makehuman.log
(8.62 KiB) Downloaded 643 times
thecreativefool
Postby orangetheripper » Mon Dec 30, 2019 11:03 pm
thecreativefool wrote:I am having the same problem. I've attached my log file; I'm running Windows 10 with a 64-bit operating system and an i7 processor. Let me know what could be happening.
Are you running a laptop? I got the same thing and had to force the pythonw.exe file inside of appdata/local/makehuman-community/python (you can see it as the first part in the properties of the shortcut) to use my discrete graphics card.
orangetheripper
Postby joepal » Wed Jan 01, 2020 3:56 pm
I've updated http://www.makehumancommunity.org/wiki/ ... _not_start with information about telling pythonw to use the discrete graphics card.
Postby senatejo » Sun Apr 04, 2021 6:37 am
hey, i have same trouble here. but i found the solution.
you can install Vcredist x64 in your laptop/pc. Then, you could open your makehuman again.
senatejo
