Missing MPFB2 in Blender 4.2
Postby DennisDiamante » Sat Aug 10, 2024 6:02 am
Hello everyone. I am new to both blender and makehuman.
I installed MPFB2 to blender 4.1 days ago and was able to run it inside blender. When I tried to install makehuman system assets as add on in blender, I ran into a problem of the add-on not appearing in search after installing. I was not able to run makehuman system assets in blender 4.1.
I decided to upgrade my blender to 4.2
Now, MPFB2 is also missing. I tried installing it agin as add on but MPFB2 now is not showing in the search after installation.
Please help. Thank you
DennisDiamante
Re: Missing MPFB2 in Blender 4.2
Postby tomcat » Sat Aug 10, 2024 11:54 am
DennisDiamante wrote:Now, MPFB2 is also missing.
You need to look for "MPFB," not "MPFB2."
Postby DennisDiamante » Sun Aug 11, 2024 1:51 am
Hello. I am now able to run mpfb2 in blender 4.2. I use the nightly build dated August 10, 2024 but is still unable to load the system assets pack. Blender displayed pop up message that 'assets should be available by now' after I loaded system assets packs through the 'load packs from zip file' button under APPLY ASSETS>LIBRARY SETTINGS. Screenshot with blender pop-up message is attached. Screenshot of showing empty assets library after restarting blender is also attached.
Thanks.
DennisDiamante
Postby Ricardo2020 » Sun Aug 11, 2024 4:00 am
The method for asset installation is correct as you describe. However, it is complaining about not being able to find the asset pack zip files.
The solution is rather simple. Go to the asset pack zip file page:
https://static.makehumancommunity.org/assets/assetpacks.html
Download all the files on this page to your download folder.
Launch Blender, tap the N key to bring up the tool shelf to the right of the viewport.
Tell MPFB where those zips are at as you install them.
Once completed, you will have a very full library.
Postby joepal » Sun Aug 11, 2024 10:12 am
It should work. I'll be interested in seeing screenshots of how the data dir looks after the installation of an asset pack.
You can find the user data dir by going to the "system and resources" panel, "directories" and clicking "user data".
You should there find a folder called "data". I'd like screenshots of that dir, the data/packs dir and the data/clothes dir.
Postby DennisDiamante » Mon Aug 12, 2024 7:26 am
joepal wrote:It should work. I'll be interested in seeing screenshots of how the data dir looks after the installation of an asset pack.
Hi Joel, I hope I attached the right screenshots that you were asking. The path directory is shown at the button of each screenshot.
Thank you
DennisDiamante
Postby DennisDiamante » Mon Aug 12, 2024 8:02 am
Ricardo2020 wrote:The method for asset installation is correct as you describe. However, it is complaining about not being able to find the asset pack zip files.
Not sure if you were talking about the 'Overide secondary root:' under Asset roots. Anyway, I put the path directory there and it worked! I can now access the assets.
Thank you so much!
DennisDiamante
Postby Ricardo2020 » Tue Aug 13, 2024 7:57 am
Always glad to be of service.
I look forward to seeing some renders from your setup.
Postby joepal » Tue Aug 13, 2024 8:07 am
Something is strange here. From your screenshots, it looks as if you have managed to install the asset pack. I cannot immediately see why it is not read. This is a bit worrying, since it might indicate there's a bug in there somewhere.
Debugging this would take a bit of effort. But I'd have to look through the code a bit to figure out what to look closer at.
Postby Ricardo2020 » Tue Aug 13, 2024 2:09 pm
I agree, Joe.
However, I was able to get everything up and running on the first try using the instructions given on this site. I can make humans from scratch or via import model from MakeHuman. The preset creation works well. The import method is a little trickier and not all the options work with that, which is to be expected. This is not a problem for me. I can go either way, depending on what the end result needs to be used for.
What I am having trouble with is getting my custom poses into the pose library. I can generate poses by exporting single frame BVH files which MakeHuman can read and use. Getting these files into the MPFB setup as poses in the Library is something I have yet to figure out. I know how to make the thumbs but not the meta data files. I know to put all the files inside a folder of the same name, but not how to get them to show up in the library.
Many thanks for all that you do, my Good Sir.
