DAE Export problems
DAE Export problems
Postby oobi007 » Fri May 07, 2021 6:38 am
Hello,
i try to export a model as DAE, for use in Cinema4D
My first try works perfekt, but since my second try it wont work anymore.
The textures are not on the mesh, the model is only gray.
When i load my first try in C4D then here are any "...exportMesh" entrys with the textures.
Why does makehuman exports this meshes no more?
oobi007
Re: DAE Export problems
Postby joepal » Fri May 07, 2021 7:59 am
It is very difficult to answer this without knowing what you do when you export.
Can you send screenshots on:
* How the model looks in MH
* What options you select when exporting
* How the directory with the export looks. Of particular interest is the "textures" subdir which should be where the exported file is saved.
Postby oobi007 » Fri May 07, 2021 12:45 pm
Hello,
here are s few screenshots.
Regards
Oliver
Screenshot C4D
directory export
makehuman export
oobi007
Postby joepal » Sat May 08, 2021 8:14 am
Textures are not included in the DAE file. They're saved as separate files in the textures directory.
I have no idea how Cinema4D works. But I imagine there must be a material settings panel somewhere. In this you should be able to see what the diffuse texture points at. My guess is that Cinema4d has failed to populate this setting, or somehow gotten it wrong. The easy fix would be correcting the setting of this field.
Postby oobi007 » Sat May 08, 2021 8:33 am
when i load the model in cinema4d, the textures where shown in the materials panel, but they where not be placed on the mesh.
oobi007
