help with render
help with render
Postby gwc42 » Mon Aug 12, 2019 9:37 am
I have recently installed ubuntu 18.04, and MH 1.1.1 via apt install.
I cant seem to get render to work, it just shows a black silhouette. This is in render and viewer, scene works fine but i think you cant save/export image from scene. I have tried with different skin material but that makes no difference. It is as though i need to set up lighting arrangement for render but i cant see a way to do that.
Please advise.
Gary
gwc42
Re: help with render
Postby RobBaer » Tue Aug 13, 2019 4:40 am
It is likely that you don't have the mesa drivers or graphics card driver completely/correctly installed yet. This is likely to help you unless your graphics card is old or you are unlucky. If you fall into later category, try starting MH with the --noshaders switch. It may bail you out.
Maybe not exactly what you are looking for, but the camera icon next to the "?" will do a screen grab and save it in the ~\Documents\makehuman\v1\grab folder.
