Missing Community Tab
Postby XPomJohn » Sat Dec 01, 2018 9:05 am
I've downloaded 1.2.0 via the PPA but when I open Makehuman I don't have a Community tab, which should be next to the Help tab. Is this a bug or am I missing something? I'm using Linuxmint 19.
Thanks.
XPomJohn
Re: Missing Community Tab
Postby joepal » Sat Dec 01, 2018 4:10 pm
This should work. Maybe something is different in what Qt libs are available? I'm not familiar with linux mint versions, but Qt needs to be at least 5.9.5 and PyQt 5.10. These are the versions available in ubuntu 18.04.
Can you try starting up makehuman again, then immediately close it, and then post the makehuman.log file found in ~/makehuman/v1py3 ?
Also, can you post the output of:
dpkg -l | grep -i makehuman
and finally, can you post the output of:
ls -l /usr/share/makehuman-community/plugins
Postby XPomJohn » Sun Dec 02, 2018 5:07 am
Thanks for your quick response Joepal. It looks as if the dependences are at fault so that's what I look at first before posting anything else
XPomJohn
Postby XPomJohn » Wed Dec 05, 2018 5:37 am
I've checked my system and am now confident that the dependencies are OK. I've attached the 3 outputs so hopefully you can come up with a solution. Thanks
dpkg output.txt
(828 Bytes) Downloaded 383 times
ls -l output.txt
(2.92 KiB) Downloaded 357 times
makehuman.log
(31.98 KiB) Downloaded 366 times
XPomJohn
Postby joepal » Wed Dec 05, 2018 9:26 am
It would seem mint handles "recommends" and "suggests" type dependencies in a different way than ubuntu. What has happened here is that the appropriate packages simply haven't been installed.
To fix, run:
apt-get install makehuman-community-plugins-assetdownloader makehuman-community-plugins-socket mhx2-makehuman-exchange
To get a list of other packages that might be interesting, run:
apt-cache search makehuman-community
Postby XPomJohn » Thu Dec 06, 2018 5:28 am
attached are the results of apt-cache plus details from synaptic package manager of installed dependencies. Thanks once again for spending your time to help me out.
apt-cache.txt
(1.21 KiB) Downloaded 376 times
XPomJohn
