Unable to export on a mac
Postby Colabean » Mon Jun 18, 2018 10:11 pm
Hello
Hopefully this is not to complicated!
I have had a play and thought I would export something to print but when I go to the export page and select the file format; I click on 'export' and absolutely nothing happens....
What can I do?
Many thanks
Nicola
Colabean
Re: Unable to export on a mac
Postby Aranuvir » Mon Jun 18, 2018 10:31 pm
Can you check the "Logs" tab, if there are any error messages?
Postby RobBaer » Tue Jun 19, 2018 2:53 am
Colabean wrote:Hello
What can I do?
Many thanks
Nicola
The camera on the top right will screen capture your image to the disk for "printing" if that was your real goal. It will be in /documents/makehuman/v1/grab.
If your were really exporting, what format did you choose? Did you type a name in the blank to the left of the export button? Did you see a progress bar when you clicked on export? Did you look in /documents/makehuman/v1/export for the file you saved?
