question about creating targets
Postby cybrmagi » Sun Jun 03, 2018 3:11 am
So from what I read in the manual you create targets by loading the base mesh then modifying it. Now I have a mesh that is pre-made that I would like to turn into a target. Is that possible and if it is how do I do it?
Also have blender 2.76 and I installed and enabled the make-target add-on but it does not show up where the tutorial says it would be.
Any help with these issues would be much appreciated.
cybrmagi
Re: question about creating targets
Postby loki1950 » Sun Jun 03, 2018 3:50 am
The maketarget script's GUI should be on the right self if that is not visible hit "N" it will be near the bottom of the stack with it you load the base mesh that is what you modify not add on other mesh.If it's not there you may have forgotten to save settings at the bottom of the Preferences window where you activated the addon.
