I do not use vapor-ware. I use script files for everything so there is an audit-trail.
I am a NUG to Python and MH, which I eventually expect to use in the future. I jumped off the deep end with Marc's tutorial 01-Plug-ins. I did not find _example.py, but I did find _example_plugin.py in C:\MyProgramFiles\MakeHuman\plugins. Note: MyProgramFiles is a POSIX link to the usual Windows folder “Program Files” but it is devoid of any spaces in the path to make the full path UNIX (and Python compatible). After a lot of reading of O'Reilly's two Python books, I was able to create script files that get things breathing. So that Python knows where to find the MH script files, especially the first import file “gui3d.py”, in the DOS script file, I have set:
set PYTHONPATH=C:\MyProgramFiles\MakeHuman\mh_core
I now execute _example_plugin.py. Things truck along fine until the process gets to:
File "C:\MyProgramFiles\MakeHuman\mh_core\module3d.py", line 43, in <module> import mh
ImportError: No module named mh
As a NUG, I do not have a clue how to debug this error fault.
Note: there is a Python library file mh.pyd at C:\MyProgramFiles\MakeHuman\mh.pyd
I know something is missing. Any suggestions? Sorry for the verbosity and the NUGosity.
Thanks millions.
Keith.
