Hello!
I would like to know if, when I create an asset from the makehuman helper, I can add different objects, that don't belong to the helper at the begining, and fusion them to a part of the helper to create the final asset. If I do it, will the weightingd be affected? Is it better to use only the parts belong to the helper?
Thank you in advance for your answer!
