Organizing Targets
Organizing Targets
Postby Ricardo2020 » Sun Sep 26, 2021 4:23 pm
My custom folder inside MakeHuman/Home has hundreds of targets. Leaving them all inside one folder caused the list of sliders to become overwhelming to the point of taking a lot of time just to find the desired control. So, I did the logical thing. I created sub folders and put the relevant targets inside of them.
MakeHuman/Home/Data/Custom
Target folders on main workstation running Linux Mint
Now that the targets are sorted, they become much easier to find. When I select custom, the sliders are still in the left pane, but the right pane is now populated with the folders. Selecting a folder brings up those targets it contains in the left pane.
Thus, I spend much less time hunting down a given target and much more time playing with the sliders. It streamlines my work flow tremendously!
Re: Organizing Targets
Postby punkduck » Mon Oct 11, 2021 7:17 pm
It would be best before you create models. For all who did that later (like myself :shock: and I guess this would happen in most cases) there is some additional work --- you have to change your model files.
search for "custom" and then enter the subdirectory before the file name.
So given that you created a folder mouth and used
modifier custom/close_lips
it must be
modifier custom/mouth-close_lips
now. Otherwise the missing target is skipped.
Postby Ricardo2020 » Mon Oct 11, 2021 8:54 pm
Many thanks, punkduck.
This helps tremendously since the path statements within these text files are a cinch to edit using the corrected syntax you have given. Now to go about doing that for my vast collection of models, now numbering in the hundreds...
What would really be neat is a path parser/updater utility which could update these paths within the target statements inside a given model file. It could be a simple stand alone device or even incorporated into MH so that, when paths change, they can be easily updated.
Many thanks for the advice.
