How do i fix the textures not showing up in makehuman
Postby prittypony1 » Tue Aug 30, 2022 2:02 am
How do i fix this? The model I downloaded doesn't have the png file.
These are whats included in the model file
Which program do i open to change one of these files so it can be textured correctly?
prittypony1
Re: How do i fix the textures not showing up in makehuman
Postby tomcat » Tue Aug 30, 2022 5:27 am
prittypony1 wrote:These are whats included in the model file
These are not all the files you need. You also need a texture.
Optional diffuse texture:
How did you install the Asset? Maybe if you download and place the texture correctly it will pick it up. If not, then:
Utilities -> Material Editor (plugin must be activated) -> [Clothing] -> Diffuse texture
Postby munch » Sat Jun 15, 2024 7:40 am
And I've noticed on your nodes that you're using the incorrect node for the normal map. You're using the Bump node when you should probably use the Normal Map node.
And don't forget to change the normal image texture from sRGB to non-color as well!
munch
