Installed but will not run
Postby reapersremorse » Sun Jun 07, 2020 3:10 am
Version: makehuman-community-1.2.0-beta1-windows.zip
i looked here: http://www.makehumancommunity.org/wiki/ ... _report%3F
for information on how to properly submit this
then looked here: http://www.makehumancommunity.org/wiki/ ... _directory)%3F
in order to find my logs
no logs were created that i can find
i installed the program on my B drive
https://imgur.com/G3zevkQ
https://imgur.com/W0T4EIG
https://imgur.com/kTgOji2
So does this mean its my gpu? the installer did all the work so idk if its my error or if my system isnt good enough.
specs:
os: windows 10 pro
System type: 64X-based pc
Processor: MAD Ryzen 7 2700x Eight-Core processor, 3700 mhz, 8 Core(s), 16 Logical Processor(s)
SMBIOS Version: 2.8
BIOS Mode: legacy
BaseBoard: X470 GAMING PLUS (REDACTED)
Installed Physical Memory (RAM): 32GB
Total Physical Memory: 31.9GB
GPU: geforce gtx 1060, 6GB
im very tired from work so i assume i did something stupid.
reapersremorse
Re: Installed but will not run
Postby joepal » Sun Jun 07, 2020 11:49 am
There is a bug with the desktop icon currently.
Can you try running makehuman from the start menu and see if that helps?
Postby joepal » Sun Jun 07, 2020 12:12 pm
I've uploaded a new nightly build now. Can you check if this solves the problem?
If not, can you tell me what the desktop icon shortcut points at?
Postby RobBaer » Sun Jun 07, 2020 4:23 pm
joepal wrote:I've uploaded a new nightly build now. Can you check if this solves the problem?
The nightly build shortcut worked fine for me. Patch release?
Postby joepal » Mon Jun 08, 2020 10:39 am
I think we should release beta2 with punkduck's symmetry stuff and whatnot within the nearest future anyway. For now, we should point people towards the nightly if they have problems starting the program.
