Export/transfer targets from MakeHuman into Blender
Postby fraang » Wed Aug 28, 2019 4:18 pm
I would like to suggest a feature in MakeHuman (and/or the Blender add-on) to export/transfer the available targets used in MakeHuman into Blender using shape keys. This would make it possible to use the existing, extensive human character modelling capabilities inside blender but more importantly inside game engines to create an in-game character customization feature. I am not sure about the licensing though. Any suggestions/ideas for the implementation? I would be volunteering on the coding side but could use some infos/pointers to the right places. :)
fraang
Re: Export/transfer targets from MakeHuman into Blender
Postby Aranuvir » Wed Aug 28, 2019 4:26 pm
The tool already exists and is called MakeTarget. It can also load targets from file.
Postby fraang » Thu Aug 29, 2019 8:12 am
Should this work in MakeTarget2? I tried it there and it didn't. At least it seems that way. :-(
fraang
Postby joepal » Thu Aug 29, 2019 8:27 am
As far as I know, loading targets works in mt2. But:
* They wont modify clothes
* They wont modify a body proxy
So only the body (the base mesh) is affected.
If this doesnt work, then that's a bug. Screenshots are welcome in that case.
Postby fraang » Thu Aug 29, 2019 4:01 pm
Ok 1 target can be loaded but not more. Is this intended?
fraang
Postby joepal » Fri Aug 30, 2019 7:57 am
"Intended" is maybe a bit strong. But yes, it's a limitation of the current implementation that there is only one target slot.
Postby polylearn » Thu Sep 12, 2019 6:42 pm
I was looking for something similar a while ago when trying to combine animation of the MakeHuman targets themselves with armature animation in Blender.
It is simple enough to do this for single targets with the application socket connection, a) import your chosen base human type into Blender, b) apply one target in MH and import the modified model on top of the base one, c) select modified human, then the base human and "Join as shapes", d) rename resulting shape key of the base human to something meaninful and delete the additional model. These steps take only about a minute per target, but there are hundreds of targets in MakeHuman so it quickly becomes quite tedious trying to create a full library of them.
I imagine it might be possible to write a pair of add-ons for transferring the targets (or a script for Blender to read target specs from the .npy files?), but there are a few additional challenges which make it difficult to even come close to MakeHuman's functionality:
- The resulting shape keys do not always mix in the same way as the MH targets do, especially in the case of the macro targets. I believe MH does the macro targets by combinations of some data sets which are not directly accessible by other means, but I forgot where I saw these listed. Anyway, in Blender you would have to create shape keys for not only the macro targets but also several cross-combinations of them to achieve similar results.
- MakeHuman scales the skeleton automatically if you use any targets which lengthen or shorten body parts. There doesn't seem to be any way to do this with Blender, so for animating these kinds of shape keys you would also have to import rigs for each different character size and shape and then animate the armature modifier visibility from one to the other.
- Hair, body parts, clothes, etc; you could create a library .blend file to include some subset of the available assets but how to fit different human shapes, I honestly have no idea about this.
Additionally, shape keys are topology-specific but the old MeshTransfer Blender add-on can be used to copy shape keys to other topologies even if vertex numbers don't match, as long as the meshes are close enough in 3d space.
Probably in 99.9% of cases there's simply no reason to bother with trying to implement something like this because the socket connection makes it so fast and easy to use MH and Blender side by side. But, I already once spent a full evening creating a blend file with maybe a couple hundred shape keys for the MH base human so if someone wants to make something with it, I could post it here or elsewhere.
polylearn
Postby AssetDK » Mon Apr 13, 2020 2:25 pm
There is a tool to transfer the shape keys between similar meshes: https://www.youtube.com/watch?v=-zBlaedkkVs&t=16s
However it will go over every Vertex and it takes a LOT of time. Thus it works better for smaller meshes. I am working on getting to do this for 'all' targets... i will let you know if I make any progress.
The actual problem getting targets seamlessly into Blender appears to stem from the fact that there is a topology issue. That is when you character is done with some other topology the targets will not transfer!
AssetDK
MakeShapes - Re: Export/transfer targets from MakeHuman
Postby AssetDK » Tue Apr 21, 2020 9:50 am
I made an addon, not flawless but can be used! ;)
viewtopic.php?f=20&t=18528
AssetDK
