Cannot install makehunan official
Postby frantas » Tue Aug 20, 2019 8:51 am
Hello,
trying to install on Ubuntu 18.04 I get this:
sudo add-apt-repository ppa:makehuman-official/makehuman-11x
Err:21 http://ppa.launchpad.net/makehuman-offi ... 11x/ubuntu bionic Release
404 Not Found [IP: 91.189.95.83 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/makehuman-official/makehuman-11x/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
sudo apt-get update
Err:7 http://ppa.launchpad.net/makehuman-offi ... 11x/ubuntu bionic Release
I know this is more for the bugtracker but this site is unfortunately down.
I hope someone can address this to the package maintainers.
I tried the community version too but this has unresolved dependencies.
frantas
Re: Cannot install makehunan official
Postby Aranuvir » Tue Aug 20, 2019 9:43 pm
404 Not Found
1.1.X was not build for Bionic. Run the alpha version.
Postby joepal » Wed Aug 21, 2019 5:14 am
It should work with bionic. What was missing?
Postby frantas » Sun Aug 25, 2019 7:27 am
Hello,
sorry I have reopened #57. This one was closed without taking any action.
The Errors didn't vanish (I retried both 1.2 and 1.1 right now)
Due to Aranuvir the (due to the makehuman web) official stable release 1.1 was not built.
Do I get this right?
And to run the alpha version.
The alpha version is 1.2 - again, do I get this right?
For this I got from Joepal "It should work" .... but unfortunately it doesn't.
And the question "What was missing?" .... well, 404 Not Found
frantas
Postby joepal » Sun Aug 25, 2019 9:07 am
frantas wrote:Hello,
From the log output you pasted, it is clearly visible that you try to install ftom the 1.1.x PPA. There is no version for bionic there since 1.1.x isnt compatible with it.
The suggestion was to instead use the 1.2.x PPA at https://launchpad.net/~makehuman-offici ... -community. This contains builds for bionic, as can be seen in the package list at https://launchpad.net/~makehuman-offici ... /+packages.
If you cannot install "makehuman-community" from the newer repo, I would see a log output from that in to understand what happens.
Postby frantas » Sun Aug 25, 2019 10:49 am
Thanks for the reaction,
The output was in my former post already.
Using the link in your post (I think it is the same I used before). Here we go again
frank@frankies:~$ su -
Password:
root@frankies:~# add-apt-repository ppa:makehuman-official/makehuman-community
This PPA contains builds of MakeHuman 1.2.x, bundled with community addons (such as MHX). The MakeHuman Community 12x series is a different code branch than the MakeHuman 11x code. The source for MakeHuman and most of the addons can be found at https://github.com/makehumancommunity.
Packages from this PPA should be possible to install and run alongside packages from the makehuman-11x PPA.
To enable the PPA and then install MakeHuman, run:
sudo add-apt-repository ppa:makehuman-official/makehuman-community
sudo apt-get update
sudo apt-get install makehuman-community
On ubuntu this will install all plugins as they are "Recommends" in the packages. If you have switched off "Recommends", or if you are using Mint, you might also want to do:
sudo apt-get install makehuman-community-plugins-socket makehuman-community-plugins-assetdownloader mhx2-makehuman-exchange
This will install some plugins you are likely to want.
For more information, see http://www.makehumancommunity.org
This PPA also contains optional packages. The "makehuman-blendertools" package installs blender integration. The "makehuman-targets-dev", "makehuman-clothes-dev", "makehuman-hair-dev" and "makehuman-bodyparts-dev" contain raw targets and obj files for targets, clothes, hair and body parts respectively. Most people do not need the "*-dev " packages, but if you plan to develop new targets, the "makehuman-targets-dev" might make sense.
If you have questions, ask them on the MakeHuman forum: http://www.makehumancommunity.org/forum
If you need to make a bug report, post it on the MakeHuman bug tracker: http://bugtracker.makehumancommunity.org
More info: https://launchpad.net/~makehuman-offici ... -community
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 http://cz.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://cz.archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB]
Get:3 http://cz.archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB]
Get:4 http://cz.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [285 kB]
Get:5 http://cz.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [70,9 kB]
Get:6 http://cz.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [140 kB]
Get:7 http://cz.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [253 kB]
Get:8 http://cz.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [205 kB]
Get:9 http://cz.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [453 kB]
Get:10 http://cz.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2 468 B]
Get:11 http://cz.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7 928 B]
Ign:12 http://ppa.launchpad.net/makehuman-offi ... 11x/ubuntu bionic InRelease
Hit:13 http://ppa.launchpad.net/makehuman-offi ... ity/ubuntu bionic InRelease
Get:14 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Err:15 http://ppa.launchpad.net/makehuman-offi ... 11x/ubuntu bionic Release
Get:16 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [22,7 kB]
Get:17 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [10,4 kB]
Get:18 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [31,7 kB]
Get:19 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [42,1 kB]
Get:20 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16,4 kB]
Get:21 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [111 kB]
Get:22 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2 464 B]
root@frankies:~#
frantas
Postby frantas » Sun Aug 25, 2019 11:04 am
I see:
the Err 15 line points to http://ppa.launchpad.net/makehuman-offi ... 11x/ubuntu
The PPA is for 1.2 but there are gets for 1.1x (this is not the only one) The Ign 12 InRelease points to the same.
I don't know the structure of the project tough. This can be by intention.
frantas
Postby joepal » Sun Aug 25, 2019 1:31 pm
There is no error here. Apt properly reports that there is no bionic build in the 11x repository. This is correct: there is no bionic build there.
Then it reports that the 11x repository has been disabled, since there's no bionic build there. This is also the appropriate thing to do, since you can't install from there anyway.
On line 13 ("hit: 13"), it seems to update from the makehuman-community repo, without reporting any error.
The only problem you have here is that you get a warning for the 11x repository that you still have enabled. This is unrelated to the makehuman-community repository, which you seem to have properly enabled. Since you can't use the 11x repository anyway, the appropriate thing to do would be to disable it: https://itsfoss.com/how-to-remove-or-de ... quick-tip/
What remains for you to do is to run "apt-get install makehuman-community", as per the instructions that are printed in the console. Having done so, you will (most likely) get a working makehuman installation.
Postby Aranuvir » Sun Aug 25, 2019 4:07 pm
running some ppa-purge to remove outdated repos might be beneficial, too.
Postby frantas » Sun Aug 25, 2019 10:39 pm
Aranuvir wrote:running some ppa-purge to remove outdated repos might be beneficial, too.
In case this was for me:
How do I run some ppa-purge? Sorry - I am not a developer, I am a 3d creator working with blender.
frantas
