MH 1.2.0 loades then crashes.
Postby TAIPANSC » Wed Feb 06, 2019 10:52 pm
TAIPANSC
Re: MH 1.2.0 loades then crashes.
Postby joepal » Thu Feb 07, 2019 2:05 pm
We need more information to be able to do anything about this.
http://www.makehumancommunity.org/wiki/ ... _report%3F
Postby TAIPANSC » Fri Feb 08, 2019 11:18 am
Thank you for your response
Roger that, please review attached files.
python_out file has no data
makehuman.log
(8.5 KiB) Downloaded 457 times
python_err.txt
(5.56 KiB) Downloaded 442 times
makehuman-debug.txt
(2.41 KiB) Downloaded 477 times
TAIPANSC
Postby pandenista » Thu Mar 28, 2019 7:08 am
It's just the same problem as mine, the same error logs.
In my case:
Intel Core i7 (2.6 and 2.59 GHz)
16 GB RAM
Windows 10, 64bit
NVidia GeForce GTX 965M
OpenGL 4.5
Installed python 3.7 32bit (but MH uses it's own python)
pandenista
Postby RobBaer » Thu Mar 28, 2019 12:38 pm
If your error logs are literally the same as TAIPANSC error logs, I think you have somehow not downloaded the latest version which should have a version line that says,
DEBUG -- VERSION: 1.2.0 Alpha3
TAIPANSC error log refers to what was an earlier alpha build (although it wasn't properly tagged as such at the time),
[2019-02-06 16:58:52,701] log.py->debug():113 -- DEBUG -- VERSION: 1.2.0
The error in the log seems related to an opengl error that occurred most frequently on AMD graphics cards (and some Mac OSXs with Nvidia cards). It is not clear that there were not other systems that suffered like TAIPANSC Intel graphics card.
I recommend downloading again from the URL below and seeing if things don't go better:
http://download.tuxfamily.org/makehuman ... -win32.zip
You should also read the corresponding release notes here:
http://www.makehumancommunity.org/wiki/ ... o_download
Postby pandenista » Sat Mar 30, 2019 6:41 pm
I tried it again on version Alpha 3 and the result is the same.
Thanks, Martin.
makehuman-debug.txt
(2.7 KiB) Downloaded 464 times
makehuman.log
(9.07 KiB) Downloaded 440 times
python_err.txt
(6.01 KiB) Downloaded 438 times
pandenista
Postby Aranuvir » Sun Mar 31, 2019 1:06 pm
@pandenista:
A) Currently you are using Intel's GPU for MakeHuman. Can you change your settings so it uses NVIDIA?
B) Could you try to get Intel's official GPU drivers, if still available, and retry with these drivers?
Postby pandenista » Tue Apr 02, 2019 5:54 am
Thanks for your advice. I changed my NVidia graphic card settings to be preferable and from now on everything goes well.
Thanks a lot.
Martin.
pandenista
