problem with makeclothes
Postby Marco_105 » Sat Dec 22, 2018 6:41 am
hello,
I have problem when i make clothes on mesh or object run in the past.
That upset me...
File "core\events3d.py", line 211, in callEvent
File "apps\gui\proxychooser.py", line 163, in onFileSelected
File "apps\gui\proxychooser.py", line 240, in proxyFileSelected
File "core\mhmain.py", line 858, in do
File "apps\gui\proxychooser.py", line 77, in do
File "apps\gui\proxychooser.py", line 308, in selectProxy
File "shared\proxy.py", line 166, in loadMeshAndObject
AttributeError: 'bool' object has no attribute 'priority'
Marco_105
Re: problem with makeclothes
Postby Aranuvir » Sun Dec 23, 2018 10:32 am
I assume from your words, that clothes that worked with MakeHuman 1.1.1 or 1.1.0 now are causing problems when they are loaded in MakeHuman 1.2.0alpha? It looks like there is a problem with different npz versions. These files are just some sort of data caching and can be deleted. Can you remove the npz file and retry to load the mesh? This should fix your issue.
Though MakeHuman's error handling could be improved here...
Postby joepal » Thu Dec 27, 2018 12:27 pm
I've pushed a fix that solves the crash: https://github.com/makehumancommunity/m ... 00d2b362d1. But that doesn't explain why the mesh didn't want to load in the first place.
Postby Marco_105 » Fri Dec 28, 2018 4:43 pm
Yes, its a problem with sth you speak, when I upload some clothes mesh in BL, make some adjustement and reexport in MH a message appear tell me that sth wrong, I don't know why.
Some other clothes works perfectly even it's near the same making.
I work only with MH 1.1.1 for now, I don't know exactly what that happend but this error don't appear often.
Do you think I have to try MH 1.2 ?
Marco_105
Postby Marco_105 » Sat Dec 29, 2018 2:51 pm
I try the new version... how can I make launch of this apps from contextual W7 menu ?
Marco_105
Postby RobBaer » Sun Dec 30, 2018 7:47 pm
Marco_105 wrote:I try the new version... how can I make launch of this apps from contextual W7 menu ?
Not sure I understand, but start makehuman using the "start menu" after running the installer. There will NOT be a desktop icon. You MUST use the start menu on Windows with the new installer..
Postby Marco_105 » Mon Dec 31, 2018 7:11 pm
Yes , the new feature give us new possibility and make more easy the conception, I see the progress in MH 1.2, that's great.
Usually to start the app I use contextal desktop menu, but know with python script for lauch seems impossible.
Maybe some body know how to do that ? I try to give from regedit: command Python33.exe and the name of file but it didn't start.
Anyway, the new feature for start is just a question of habit.
Marco_105
Postby RobBaer » Tue Jan 01, 2019 4:59 pm
Like you my habit is to start from the desktop.
If you installed for "anyone using the computer", create a new shortcut on your desktop, then edit shortcut with right click | Properties...
Put
"C:\Program Files (x86)\makehuman-community\Python\pythonw.exe" "C:\Program Files (x86)\makehuman-community\mhstartwrapper.py"
in the Target field
and put
%HOMEDRIVE%\%HOMEPATH%
in the Start in field.
If you installed for "just me", this will be in the (hidden) appdata directory I think. I'm not sure about Windows 7 but some thing like:
Put (as single line) in the Target field (right click | Properties)
"C:/Users/%USERNAME%/AppData/Local/makehuman-community/Python/pythonw.exe" "C:/Users/%USERNAME%/AppData/Local/makehuman-community/mhstartwrapper.py"
and put
Hope this works for you.
Postby Marco_105 » Tue Jan 01, 2019 6:44 pm
Thanks for you prompt advise, this is already the case I have create a shortcut on the desktop.
But I don't how to retrieve my old feature from desktop contextual menu...
Marco_105
Postby Marco_105 » Tue Jan 01, 2019 7:03 pm
Ah yes I found it !
from regedit :
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\Background\shell
ensuite créer un dossier "Makehuman"
ensuite créer un dossier "Command"
une clé par défaut devrait alors apparaitre "REG_SZ", mettre la valeur :
C:\Users\********\AppData\Local\makehuman-community\Python\pythonw.exe "C:\Users\********\AppData\Local\makehuman-community\mhstartwrapper.py"
et voilà !
Marco_105
