1.0.2–1.1.1: Native/vanilla skins not (completely) rendered
Postby odacaesar » Tue Dec 11, 2018 6:02 am
I have been having this problem with all skins but Default and Toon:
Aside from the aforementioned exceptions, they all look like this. Selecting different affected skins does not even change the shading. I uninstalled and reinstalled twice. I upgraded from 1.0.2 to 1.1.1. None of this has resolved the issue, or even changed this incomplete render in any visible way.
I am new to 3D modeling, but I do not see any immediately obvious errors in the logs. There is this in between skin changes:
Loading material from file data/skins\young_caucasian_male\young_caucasian_male_special_suit.mhmat
do Change material of base.obj
Creating new texture for image C:/Program Files (x86)/MakeHuman/makehuman-1.1.1-win32/data/skins/textures/[skin name with underscores].png.
initTexture: 2048, 2048, False
(The last two lines are only found for skins I have yet to click on.)
o d a c a e s a r Image
odacaesar
Re: 1.0.2–1.1.1: Native/vanilla skins not (completely) rende
Postby joepal » Tue Dec 11, 2018 7:27 am
You're most likely affected by this: http://www.makehumancommunity.org/wiki/ ... help_me%3F
Your graphics card doesn't seem to like how MakeHuman handles textures, so the only skins that work are the ones which are solid colors rather than having an image texture.
The possible workaround is to start MH with --noshaders, as described in the FAQ article.
(note that this isn't currently going to work with the alpha releases on windows)
