QSplitter
QSplitter
Postby blindsaypatten » Sat Dec 08, 2018 8:18 pm
QT5 has a QSplitter widget:
The QSplitter class implements a splitter widget.
A splitter lets the user control the size of child widgets by dragging the boundary between them. Any number of widgets may be controlled by a single splitter. The typical use of a QSplitter is to create several widgets and add them using insertWidget() or addWidget().
Could we use this in create() in the Frame class in qtui instead of GridLayout so that we can adjust the allocation of horizontal space between the three main panels?
self.h_layout = QtWidgets.QGridLayout()
self.h_layout.addWidget(self.l_panel, 0, 0)
self.h_layout.addLayout(self.t_layout, 0, 1)
self.t_layout.addWidget(self.canvas)
self.h_layout.addWidget(self.r_panel, 0, 2)
to
self.h_layout = QtWidgets.QSplitter()
self.h_layout.addWidget(self.l_panel)
self.h_layout.addWidget(self.t_layout)
self.h_layout.addWidget(self.r_panel)
With the current setup long labels sometimes get truncated because the side columns are not wide enough, e.g. if you have subdirectories in the custom folder.
I can't immediately think of any disadvantage to using QSplitter.
Pretty please!? :D
P.S. I have no experience with Qt so I might be wrong, but you might not need t_panel, top, and t_layout when using QSplitter, just adding the canvas directly might work.
Re: QSplitter
Postby joepal » Sun Dec 09, 2018 9:29 am
Without having looked into what possible side effects there might be, this sounds like a good idea.
I'm going to add it to the todo list.
Re: QSplitter
Postby blindsaypatten » Mon Dec 10, 2018 2:55 am
joepal wrote:Without having looked into what possible side effects there might be, this sounds like a good idea.
Thanks! :D
