MHX2 INSTALLED ADDONS FOR BLENDER DO NOT WORK
Postby Haru » Thu Nov 08, 2018 12:52 am
I installed and ticked everything as instructed so why is it still not working? Here are some photos https://imgur.com/gallery/peMvAlI
Haru
Re: MHX2 INSTALLED ADDONS FOR BLENDER DO NOT WORK
Postby blindsaypatten » Thu Nov 08, 2018 2:01 am
Haru wrote:I installed and ticked everything as instructed so why is it still not working? Here are some photos https://imgur.com/gallery/peMvAlI
Are you running Blender 2.80? MHX2 has not be ported to 2.80 yet so you'll have to use 2.79 for the time being, at least for the import. I have been able to import in 2.79, save to a .blend file, and then open the .blend file in 2.80.
In Blender, under the Window menu, there is an option to toggle the system console, if you do I expect that you will find a bunch of error messages.
Postby Haru » Thu Nov 08, 2018 7:38 am
Everything seems to be fine http://prntscr.com/lfrb8g also I am using 2.79, this is pretty strange
Haru
Postby blindsaypatten » Thu Nov 08, 2018 1:55 pm
Based on this:
http://diffeomorphic.blogspot.com/
it seems that in the last few days the author has produced a version for Blender 2.80.0, which I believe is what you are running, based on the top error message in your images.
I'm not sure where exactly you should get the official version for 2.79, I have attached a copy I had that you can try, I expect it will work for you until the whereabouts of the official version are found.
mhx2_blender.zip
import-runtime-mhx2 Blender addon
(720.92 KiB) Downloaded 446 times
Postby joepal » Thu Nov 08, 2018 2:31 pm
This problem should probably be reported to the MHX2 bugtracker: https://bitbucket.org/Diffeomorphic/mhx ... tatus=open
From what I can read in the source of the latest commits, Thomas seems to at least plan on supporting both blender 2.79 and 2.80. But it looks as if he's still working on it.
Unfortunately, he hasn't made any tags or branches in the repo, so it's a bit cumbersome to get the last working version (which is https://bitbucket.org/Diffeomorphic/mhx ... 396192fa00)
