loki1950 wrote:I assume that Mojave is a Linux flavour if so try running MH from a terminal you should also have posted the log file that MH generates each time you try to run it you can find that log @ home/username/makehuman/v1 that's also where you will find all the settings files.You just did not give enough info for me to figure out what is wrong.
Enjoy the Choice
yiannis wrote:loki1950 wrote:I assume that Mojave is a Linux flavour if so try running MH from a terminal you should also have posted the log file that MH generates each time you try to run it you can find that log @ home/username/makehuman/v1 that's also where you will find all the settings files.You just did not give enough info for me to figure out what is wrong.
Enjoy the Choice
I move v1 to the trash and re-installed make human.The icon bounce once and closes
loki1950 wrote:I would still like to see the log file like I said you give me NO INFO on what is happening just that it's not starting there are literally a hundred things that could go wrong and that log file will tell me exactly where in the initialisation routine of Makehuman it does go wrong and hopefully a solution.
Enjoy the Choice
how can I do that?Aranuvir wrote:Lokis questions where breezily ignored! As it turns out, Mojave seems to be some sort of beta OS from Apple. There are several reasons why MH will not work on Apple's stuff, starting from the drop of OpenGL support to some unhappy version restrictions in the macOs package (if I got this problem correctly). I fear there won't be much we can do for you.... If you depend on MakeHuman, you can try to run from a virtual machine.
Operating system survey
yiannis wrote:how can I do that?Aranuvir wrote:Lokis questions where breezily ignored! As it turns out, Mojave seems to be some sort of beta OS from Apple. There are several reasons why MH will not work on Apple's stuff, starting from the drop of OpenGL support to some unhappy version restrictions in the macOs package (if I got this problem correctly). I fear there won't be much we can do for you.... If you depend on MakeHuman, you can try to run from a virtual machine.
Aranuvir wrote:can
Aranuvir wrote:yiannis wrote:how can I do that?Aranuvir wrote:Lokis questions where breezily ignored! As it turns out, Mojave seems to be some sort of beta OS from Apple. There are several reasons why MH will not work on Apple's stuff, starting from the drop of OpenGL support to some unhappy version restrictions in the macOs package (if I got this problem correctly). I fear there won't be much we can do for you.... If you depend on MakeHuman, you can try to run from a virtual machine.
What do you want to do?
Aranuvir wrote:yiannis wrote:how can I do that?Aranuvir wrote:Lokis questions where breezily ignored! As it turns out, Mojave seems to be some sort of beta OS from Apple. There are several reasons why MH will not work on Apple's stuff, starting from the drop of OpenGL support to some unhappy version restrictions in the macOs package (if I got this problem correctly). I fear there won't be much we can do for you.... If you depend on MakeHuman, you can try to run from a virtual machine.run make human from virtual machine
yiannis wrote:loki1950 wrote:I would still like to see the log file like I said you give me NO INFO on what is happening just that it's not starting there are literally a hundred things that could go wrong and that log file will tell me exactly where in the initialisation routine of Makehuman it does go wrong and hopefully a solution.
Enjoy the Choice
how can I obtain the log file to post it to you?
