unable to instal on windows 10
Re: unable to instal on windows 10
Postby HCK_Numbers » Fri Sep 08, 2017 6:00 pm
badwolf wrote:first thing to check is did you get a complete intact download??
use 7ZIP to unpack the file into a folder directly off your C drive (im not sure the built-in zip thing in win10 is not brain dead)
I have done that thanks XD
Antiqua_Sphinge wrote:I was doing some checking on the Internet and apparently Win 10 has issues even with MS software loading and running. For some reason v10 shoots itself in the foot due to a .Net issue amongs others.
Another possibility to check is security settings under Windows.
Windows ten does have issues with it but not sure its the case here.
Edit: i don't know what i done but its working, though now its in the Downloads folder, when it was in the Desktop or Programme Files folders the error would pop up. Try just putting it into Downloads or any other non essentail folder see if that works.
HCK_Numbers
Postby Antiqua_Sphinge » Fri Sep 08, 2017 6:11 pm
Ah, the fact something works as long as it's not Desktop or Program Files based indicates it's a Win 10 Security Setting blocking the MH program.
I saw that at work years ago on an XP system modified to keep anything not approved from running.
Antiqua_Sphinge
Postby gakusei_namuhekam » Sun Jul 01, 2018 6:42 pm
I have the mistake too.
but it worked for me a few days ago.
the mistake came quite suddenly.
has anyone found a solution in the meantime?
gakusei_namuhekam
Postby RobBaer » Sun Jul 01, 2018 7:39 pm
gakusei_namuhekam wrote:I have the mistake too.
This thread is a little messy, and the messaging is confounded by mention of 7zip which typically should not be needed. Did you download the version you get by clicking the Windows link here: http://www.makehumancommunity.org/conte ... loads.html ?
If so, most browsers (I use Chrome) download a .zip to your download folder. If your Browser doesn't download when you click the link, try right clicking and choosing "Save Link to" If this is not what you are stuck on, provide more details of where you get stuck.
Postby Aranuvir » Sun Jul 01, 2018 7:56 pm
... and when you're using one of the stable releases you should make sure the path to the application does not contain any non ASCII characters. I really forgot these annoying Unicode issues.... ;)
Postby gakusei_namuhekam » Mon Jul 02, 2018 7:29 pm
i have it.
but, it does not work anyway.
can that be due to the update of windows?
Except for an update from the operating system, I have not changed anything.
and before that it went.
what else can be the cause?
gakusei_namuhekam
Postby RobBaer » Tue Jul 03, 2018 2:20 am
Highly unlikely it's the OS. I run Windows 10 regularly without incident and on some machines I running "insider previews" that are not yet released versions. MH has been stable as a rock. Very occasionally failing to reboot after an upgrade can cause issues, but this has never affected MH for me.
Can you explain "it does not work anyway". What are you doing, trying to start it? Can you provide details. If you go to C:/users/%USERNAME%/Documents/makehuman/v1 there should be a file named makehuman.log . What does it say?
Postby gakusei_namuhekam » Tue Jul 03, 2018 7:50 pm
D:\Programme\makehuman-1.1.1-win32
I start the following file;
makehuman.exe
I opened the file "license.txt" once while I opened the program and since then it has stopped working.
and MakeHuman has closed itself.
[2018-05-28 18:28:46,059] log.py->message():133 -- MESSAGE -- Initialized logging
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- VERSION: 1.1.1
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- HG REVISION: r2128 (2d119491670c) [data/VERSION static revision data]
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- SHORT VERSION: v1.1.1
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- BASEMESH VERSION: hm08
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- IS BUILT (FROZEN): Yes
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- IS RELEASE VERSION: Yes
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- DEFAULT ENCODING: utf-8
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- FILESYSTEM ENCODING: mbcs
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- STDOUT ENCODING: cp1252
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- WORKING DIRECTORY: D:\Programme\makehuman-1.1.1-win32
[2018-05-28 18:28:46,059] log.py->debug():112 -- DEBUG -- HOME LOCATION: C:/Users/.../Documents
[2018-05-28 18:28:46,061] log.py->debug():112 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;D:\Programme\makehuman-1.1.1-win32
[2018-05-28 18:28:46,061] log.py->debug():112 -- DEBUG -- DLL PATH: .;D:\Programme\makehuman-1.1.1-win32;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\GtkSharp\2.12\bin;C:\Program Files (x86)\Windows Live\Shared;C:\WINDOWS\System32\OpenSSH\;C:\Users\...\AppData\Local\Microsoft\WindowsApps;C:\Users\...\AppData\Local\GitHubDesktop\bin;C:\Users\...\AppData\Local\atom\bin;%USERPROFILE%\AppData\Local\Microsoft\WindowsApps;
[2018-05-28 18:28:46,061] log.py->debug():112 -- DEBUG -- SYS.VERSION: 2.7.13 (v2.7.13:a06454b1afa1, Dec 17 2016, 20:42:59) [MSC v.1500 32 bit (Intel)]
[2018-05-28 18:28:46,061] log.py->debug():112 -- DEBUG -- SYS.PLATFORM: win32
[2018-05-28 18:28:46,061] log.py->debug():112 -- DEBUG -- SYS.EXECUTABLE: D:\Programme\makehuman-1.1.1-win32\makehuman.exe
[2018-05-28 18:28:46,065] log.py->debug():112 -- DEBUG -- PLATFORM.MACHINE: AMD64
[2018-05-28 18:28:46,066] log.py->debug():112 -- DEBUG -- PLATFORM.PROCESSOR: Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
[2018-05-28 18:28:46,066] log.py->debug():112 -- DEBUG -- PLATFORM.UNAME.RELEASE: 10
[2018-05-28 18:28:46,066] log.py->debug():112 -- DEBUG -- PLATFORM.WIN32_VER: 10 10.0.17134 SP0 Multiprocessor Free
[2018-05-28 18:28:46,115] log.py->debug():112 -- DEBUG -- NUMPY.VERSION: 1.11.2
[2018-05-28 18:28:46,128] acceleratesupport.py-><module>():13 -- MESSAGE -- OpenGL_accelerate module loaded
[2018-05-28 18:28:46,131] arraydatatype.py-><module>():270 -- MESSAGE -- Using accelerated ArrayDatatype
[2018-05-28 18:28:46,335] log.py->debug():112 -- DEBUG -- PYQT.VERSION: 4.8.7
[2018-05-28 18:28:46,341] log.py->debug():112 -- DEBUG -- PYQT.JPG_SUPPORT: supported
[2018-05-28 18:28:46,342] log.py->debug():112 -- DEBUG -- PYQT.SVG_SUPPORT: supported
[2018-05-28 18:28:46,342] log.py->debug():112 -- DEBUG -- QT.PLUGIN_PATH: D:\Programme\makehuman-1.1.1-win32\qt4_plugins;D:/Programme/makehuman-1.1.1-win32
[2018-05-28 18:28:46,342] log.py->debug():112 -- DEBUG -- QT.PLUGIN_PATH_ENV:
[2018-05-28 18:28:46,342] log.py->debug():112 -- DEBUG -- QT.CONF: [Paths]
         Prefix = .
         Plugins = qt4_plugins
[2018-05-28 18:28:46,466] log.py->debug():112 -- DEBUG -- PYOPENGL.VERSION: 3.1.0
[2018-05-28 18:28:46,471] log.py->debug():112 -- DEBUG -- GL.VENDOR: Intel
[2018-05-28 18:28:46,473] log.py->debug():112 -- DEBUG -- GL.RENDERER: Intel(R) HD Graphics 4600
[2018-05-28 18:28:46,476] log.py->debug():112 -- DEBUG -- GL.VERSION: 4.3.0 - Build 20.19.15.4835
[2018-05-28 18:28:46,477] log.py->debug():112 -- DEBUG -- GLSL.VERSION: 4.30 - Build 20.19.15.4835
[2018-05-28 18:28:46,480] numpymodule.py-><module>():30 -- WARNING -- Unable to load numpy_formathandler accelerator from OpenGL_accelerate
[2018-05-28 18:28:46,480] log.py->debug():112 -- DEBUG -- GL.EXTENSION: GL_ARB_multisample enabled (4x samples)
[2018-05-28 18:28:46,484] log.py->debug():112 -- DEBUG -- Creating new texture for image data/textures/texture_notfound.png.
[2018-05-28 18:28:46,492] log.py->debug():112 -- DEBUG -- GL.EXTENSION: GL_ARB_texture_non_power_of_two enabled
[2018-05-28 18:28:46,496] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-05-28 18:28:46,546] log.py->debug():112 -- DEBUG -- Setting language to english
[2018-05-28 18:28:46,546] log.py->debug():112 -- DEBUG -- Setting language to german_generic
[2018-05-28 18:28:46,549] log.py->message():133 -- MESSAGE -- Initializing default theme first.
[2018-05-28 18:28:46,551] log.py->message():133 -- MESSAGE -- Theme default version 1.1.0
[2018-05-28 18:28:46,551] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/default.mht
[2018-05-28 18:28:46,552] log.py->debug():112 -- DEBUG -- Using Qt system style windowsvista
[2018-05-28 18:28:46,707] log.py->message():133 -- MESSAGE -- Loading human
[2018-05-28 18:28:46,709] log.py->debug():112 -- DEBUG -- Loading binary mesh data/3dobjs/base.npz.
[2018-05-28 18:28:46,782] log.py->debug():112 -- DEBUG -- Loading material from file data/skins/default.mhmat
[2018-05-28 18:28:46,792] GL_2_0.py->glGetActiveUniform():374 -- WARNING -- D:\Programme\makehuman-1.1.1-win32\OpenGL\GL\VERSION\GL_2_0.py:374: FutureWarning: comparison to `None` will result in an elementwise object comparison in the future.
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 0_modeling_9_custom_targets
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 0_modeling_9_custom_targets
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 9_export_light
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 9_export_light
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_eyelashes
[2018-05-28 18:42:55,161] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_eyelashes
  File "core\mhmain.py", line 559, in unloadPlugins
  File "plugins/3_libraries_eyelashes.py", line 85, in unload
    taskview.onUnload()
  File "lib\filecache.py", line 296, in onUnload
  File "lib\filecache.py", line 307, in storeCache
  File "lib\filecache.py", line 316, in saveCache
  File "lib\filecache.py", line 69, in save
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/eyelashes_filecache.mhc'
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 7_logging
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 7_logging
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 4_rendering_9_viewer
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 4_rendering_9_viewer
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 9_export_bvh
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 9_export_bvh
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 2_foot_posing
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 2_foot_posing
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 6_help
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloaded plugin 6_help
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_skeleton
[2018-05-28 18:42:55,161] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_skeleton
  File "plugins/3_libraries_skeleton\__init__.py", line 72, in unload
    maintask.onUnload()
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/skeleton_filecache.mhc'
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_eye_chooser
[2018-05-28 18:42:55,161] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_eye_chooser
  File "plugins/3_libraries_eye_chooser.py", line 95, in unload
    taskview.onUnload()
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/eyes_filecache.mhc'
[2018-05-28 18:42:55,161] log.py->message():133 -- MESSAGE -- Unloading plugin 7_expression_mixer
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 7_expression_mixer
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_tongue
[2018-05-28 18:42:55,171] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_tongue
  File "plugins/3_libraries_tongue.py", line 85, in unload
    taskview.onUnload()
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/tongue_filecache.mhc'
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_teeth
[2018-05-28 18:42:55,171] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_teeth
  File "plugins/3_libraries_teeth.py", line 85, in unload
    taskview.onUnload()
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/teeth_filecache.mhc'
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_pose
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 3_libraries_pose
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 0_modeling_background
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 0_modeling_background
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 9_export_uvmap
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 9_export_uvmap
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 0_modeling_a_measurement
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 0_modeling_a_measurement
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 9_export_ogre
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloaded plugin 9_export_ogre
[2018-05-28 18:42:55,171] log.py->message():133 -- MESSAGE -- Unloading plugin 3_libraries_eyebrows
[2018-05-28 18:42:55,171] log.py->warning():119 -- WARNING -- Could not unload 3_libraries_eyebrows
  File "plugins/3_libraries_eyebrows.py", line 85, in unload
    taskview.onUnload()
IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/eyebrows_filecache.mhc'
gakusei_namuhekam
Postby gakusei_namuhekam » Tue Jul 03, 2018 8:03 pm
[2018-05-28 18:28:46,801] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-05-28 18:28:46,802] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_ModelViewProj
[2018-05-28 18:28:46,802] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_NormalMatrix
[2018-05-28 18:28:46,802] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-05-28 18:28:46,950] log.py->message():133 -- MESSAGE -- Loaded vertex weights MakeHuman weights from file D:/Programme/makehuman-1.1.1-win32/data/rigs/default_weights.mhw
[2018-05-28 18:28:47,178] log.py->message():133 -- MESSAGE -- Loading scene
[2018-05-28 18:28:47,184] log.py->debug():112 -- DEBUG -- Loading scene file: data/scenes/default.mhscene
[2018-05-28 18:28:47,184] log.py->message():133 -- MESSAGE -- Loading main GUI
[2018-05-28 18:28:47,188] log.py->debug():112 -- DEBUG -- Assigning setting loaddir value C:/Users/.../Documents/makehuman/v1/models that was loaded before the setting was declared.
[2018-05-28 18:28:47,190] log.py->debug():112 -- DEBUG -- Assigning setting savedir value C:/Users/.../Documents/makehuman/v1/models that was loaded before the setting was declared.
[2018-05-28 18:28:47,193] log.py->debug():112 -- DEBUG -- Assigning setting exportdir value C:/Users/.../Documents/makehuman/v1/exports that was loaded before the setting was declared.
[2018-05-28 18:28:47,197] log.py->message():133 -- MESSAGE -- Loading plugins
[2018-05-28 18:28:47,204] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_0_modifiers
[2018-05-28 18:28:47,207] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_0_modifiers
[2018-05-28 18:28:47,210] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_0_modifiers
[2018-05-28 18:28:47,210] log.py->debug():112 -- DEBUG -- Loading modifiers from data/modifiers/modeling_modifiers.json
[2018-05-28 18:28:47,216] log.py->debug():112 -- DEBUG -- Attempting to load targets from NPZ file.
[2018-05-28 18:28:47,538] log.py->debug():112 -- DEBUG -- 1258 targets loaded from NPZ file succesfully.
[2018-05-28 18:28:48,078] log.py->message():133 -- MESSAGE -- Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
[2018-05-28 18:28:48,081] log.py->message():133 -- MESSAGE -- Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
[2018-05-28 18:28:48,408] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_0_modifiers
[2018-05-28 18:28:48,424] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_8_random
[2018-05-28 18:28:48,427] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_8_random
[2018-05-28 18:28:48,427] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_8_random
[2018-05-28 18:28:48,430] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_8_random
[2018-05-28 18:28:48,433] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_9_custom_targets
[2018-05-28 18:28:48,436] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_9_custom_targets
[2018-05-28 18:28:48,437] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_9_custom_targets
[2018-05-28 18:28:48,440] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_9_custom_targets
[2018-05-28 18:28:48,443] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_a_measurement
[2018-05-28 18:28:48,447] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_a_measurement
[2018-05-28 18:28:48,448] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_a_measurement
[2018-05-28 18:28:48,450] log.py->debug():112 -- DEBUG -- Loading modifiers from data/modifiers/measurement_modifiers.json
[2018-05-28 18:28:48,453] log.py->message():133 -- MESSAGE -- Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
[2018-05-28 18:28:48,454] log.py->message():133 -- MESSAGE -- Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
[2018-05-28 18:28:48,477] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_a_measurement
[2018-05-28 18:28:48,483] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_background
[2018-05-28 18:28:48,490] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_background
[2018-05-28 18:28:48,492] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_background
[2018-05-28 18:28:48,506] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_background
[2018-05-28 18:28:48,507] log.py->message():133 -- MESSAGE -- Importing plugin 2_foot_posing
[2018-05-28 18:28:48,512] log.py->message():133 -- MESSAGE -- Imported plugin 2_foot_posing
[2018-05-28 18:28:48,513] log.py->message():133 -- MESSAGE -- Loading plugin 2_foot_posing
[2018-05-28 18:28:48,513] log.py->message():133 -- MESSAGE -- Loaded plugin 2_foot_posing
[2018-05-28 18:28:48,516] log.py->message():133 -- MESSAGE -- Importing plugin 2_posing_expression
[2018-05-28 18:28:48,520] log.py->message():133 -- MESSAGE -- Imported plugin 2_posing_expression
[2018-05-28 18:28:48,522] log.py->message():133 -- MESSAGE -- Loading plugin 2_posing_expression
[2018-05-28 18:28:48,526] log.py->message():133 -- MESSAGE -- Loaded plugin 2_posing_expression
[2018-05-28 18:28:48,526] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_clothes_chooser
[2018-05-28 18:28:48,530] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_clothes_chooser
[2018-05-28 18:28:48,532] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_clothes_chooser
[2018-05-28 18:28:48,538] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_clothes_chooser
[2018-05-28 18:28:48,539] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eye_chooser
[2018-05-28 18:28:48,542] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eye_chooser
[2018-05-28 18:28:48,545] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eye_chooser
[2018-05-28 18:28:48,553] log.py->message():133 -- MESSAGE -- Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
[2018-05-28 18:28:48,555] log.py->debug():112 -- DEBUG -- Loading binary proxy data/eyes/high-poly/high-poly.mhpxy.
[2018-05-28 18:28:48,556] log.py->debug():112 -- DEBUG -- Loading proxy file: data/eyes/high-poly/high-poly.mhpxy.
[2018-05-28 18:28:48,565] log.py->debug():112 -- DEBUG -- Loading material from file D:/Programme/makehuman-1.1.1-win32/data/eyes/materials/brown.mhmat
[2018-05-28 18:28:48,572] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-05-28 18:28:48,573] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_ModelViewProj
[2018-05-28 18:28:48,573] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_NormalMatrix
[2018-05-28 18:28:48,573] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-05-28 18:28:48,575] log.py->debug():112 -- DEBUG -- Loading binary mesh D:/Programme/makehuman-1.1.1-win32/data/eyes/high-poly/high-poly.npz.
[2018-05-28 18:28:48,676] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eye_chooser
[2018-05-28 18:28:48,678] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eyebrows
[2018-05-28 18:28:48,680] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eyebrows
[2018-05-28 18:28:48,681] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eyebrows
[2018-05-28 18:28:48,684] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eyebrows
[2018-05-28 18:28:48,684] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eyelashes
[2018-05-28 18:28:48,690] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eyelashes
[2018-05-28 18:28:48,690] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eyelashes
[2018-05-28 18:28:48,690] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eyelashes
[2018-05-28 18:28:48,690] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_material_chooser
[2018-05-28 18:28:48,700] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_material_chooser
[2018-05-28 18:28:48,703] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_material_chooser
[2018-05-28 18:28:48,703] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_material_chooser
[2018-05-28 18:28:48,710] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_polygon_hair_chooser
[2018-05-28 18:28:48,710] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_polygon_hair_chooser
[2018-05-28 18:28:48,710] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_polygon_hair_chooser
[2018-05-28 18:28:48,710] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_polygon_hair_chooser
[2018-05-28 18:28:48,720] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_pose
[2018-05-28 18:28:48,720] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_pose
[2018-05-28 18:28:48,720] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_pose
[2018-05-28 18:28:48,720] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_pose
[2018-05-28 18:28:48,729] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_proxy_chooser
[2018-05-28 18:28:48,729] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_proxy_chooser
[2018-05-28 18:28:48,729] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_proxy_chooser
[2018-05-28 18:28:48,729] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_proxy_chooser
[2018-05-28 18:28:48,740] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_skeleton
[2018-05-28 18:28:48,743] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_skeleton
[2018-05-28 18:28:48,743] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_skeleton
[2018-05-28 18:28:48,750] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_skeleton
[2018-05-28 18:28:48,750] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_teeth
[2018-05-28 18:28:48,750] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_teeth
[2018-05-28 18:28:48,750] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_teeth
[2018-05-28 18:28:48,762] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_teeth
[2018-05-28 18:28:48,765] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_tongue
[2018-05-28 18:28:48,767] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_tongue
[2018-05-28 18:28:48,769] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_tongue
[2018-05-28 18:28:48,773] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_tongue
[2018-05-28 18:28:48,775] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_9_viewer
[2018-05-28 18:28:48,776] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_9_viewer
[2018-05-28 18:28:48,778] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_9_viewer
[2018-05-28 18:28:48,782] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_9_viewer
[2018-05-28 18:28:48,785] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_opengl
[2018-05-28 18:28:48,789] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_opengl
[2018-05-28 18:28:48,789] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_opengl
[2018-05-28 18:28:48,789] log.py->debug():112 -- DEBUG -- Assigning setting rendering_width value 800 that was loaded before the setting was declared.
[2018-05-28 18:28:48,789] log.py->debug():112 -- DEBUG -- Assigning setting rendering_height value 600 that was loaded before the setting was declared.
[2018-05-28 18:28:48,789] log.py->debug():112 -- DEBUG -- Assigning setting GL_RENDERER_SSS value False that was loaded before the setting was declared.
[2018-05-28 18:28:48,789] log.py->debug():112 -- DEBUG -- Assigning setting GL_RENDERER_AA value True that was loaded before the setting was declared.
[2018-05-28 18:28:48,789] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_opengl
[2018-05-28 18:28:48,799] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_scene
[2018-05-28 18:28:48,799] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_scene
[2018-05-28 18:28:48,799] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_scene
[2018-05-28 18:28:48,799] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_width is already declared. Adding it again has no effect.
[2018-05-28 18:28:48,799] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_height is already declared. Adding it again has no effect.
[2018-05-28 18:28:48,809] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_scene
[2018-05-28 18:28:48,809] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_0_settings
[2018-05-28 18:28:48,809] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_0_settings
[2018-05-28 18:28:48,809] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_0_settings
[2018-05-28 18:28:48,862] log.py->debug():112 -- DEBUG -- Setting language to german_generic
[2018-05-28 18:28:48,865] log.py->message():133 -- MESSAGE -- Theme makehuman version 1.1.0
[2018-05-28 18:28:48,868] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2018-05-28 18:28:50,164] log.py->debug():112 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2018-05-28 18:28:50,207] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_0_settings
[2018-05-28 18:28:50,220] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_mouse
[2018-05-28 18:28:50,223] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_mouse
[2018-05-28 18:28:50,223] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_mouse
[2018-05-28 18:28:50,230] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_mouse
[2018-05-28 18:28:50,233] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_shortcuts
[2018-05-28 18:28:50,234] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_shortcuts
[2018-05-28 18:28:50,236] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_shortcuts
[2018-05-28 18:28:50,253] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_shortcuts
[2018-05-28 18:28:50,257] log.py->message():133 -- MESSAGE -- Importing plugin 6_help
[2018-05-28 18:28:50,278] log.py->message():133 -- MESSAGE -- Imported plugin 6_help
[2018-05-28 18:28:50,279] log.py->message():133 -- MESSAGE -- Loading plugin 6_help
[2018-05-28 18:28:50,286] log.py->message():133 -- MESSAGE -- Loaded plugin 6_help
[2018-05-28 18:28:50,289] log.py->message():133 -- MESSAGE -- Importing plugin 7_expression_mixer
[2018-05-28 18:28:50,293] log.py->message():133 -- MESSAGE -- Imported plugin 7_expression_mixer
[2018-05-28 18:28:50,295] log.py->message():133 -- MESSAGE -- Loading plugin 7_expression_mixer
[2018-05-28 18:28:50,305] log.py->message():133 -- MESSAGE -- Loaded plugin 7_expression_mixer
[2018-05-28 18:28:50,308] log.py->message():133 -- MESSAGE -- Importing plugin 7_logging
[2018-05-28 18:28:50,309] log.py->message():133 -- MESSAGE -- Imported plugin 7_logging
[2018-05-28 18:28:50,312] log.py->message():133 -- MESSAGE -- Loading plugin 7_logging
[2018-05-28 18:28:50,325] log.py->message():133 -- MESSAGE -- Loaded plugin 7_logging
[2018-05-28 18:28:50,328] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_bvh
[2018-05-28 18:28:50,332] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_bvh
[2018-05-28 18:28:50,332] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_bvh
[2018-05-28 18:28:50,335] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_bvh
[2018-05-28 18:28:50,338] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_collada
[2018-05-28 18:28:50,342] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_collada
[2018-05-28 18:28:50,342] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_collada
[2018-05-28 18:28:50,348] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_collada
[2018-05-28 18:28:50,349] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_fbx
[2018-05-28 18:28:50,354] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_fbx
[2018-05-28 18:28:50,355] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_fbx
[2018-05-28 18:28:50,358] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_fbx
[2018-05-28 18:28:50,361] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_light
[2018-05-28 18:28:50,364] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_light
[2018-05-28 18:28:50,365] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_light
[2018-05-28 18:28:50,367] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_light
[2018-05-28 18:28:50,369] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_obj
[2018-05-28 18:28:50,374] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_obj
[2018-05-28 18:28:50,374] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_obj
[2018-05-28 18:28:50,377] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_obj
[2018-05-28 18:28:50,380] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_ogre
[2018-05-28 18:28:50,385] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_ogre
[2018-05-28 18:28:50,388] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_ogre
[2018-05-28 18:28:50,391] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_ogre
[2018-05-28 18:28:50,392] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_stl
[2018-05-28 18:28:50,395] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_stl
[2018-05-28 18:28:50,397] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_stl
[2018-05-28 18:28:50,400] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_stl
[2018-05-28 18:28:50,401] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_uvmap
[2018-05-28 18:28:50,404] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_uvmap
[2018-05-28 18:28:50,405] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_uvmap
[2018-05-28 18:28:50,407] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_uvmap
[2018-05-28 18:28:50,410] log.py->message():133 -- MESSAGE -- Loading GUI
[2018-05-28 18:28:50,443] log.py->debug():112 -- DEBUG -- showing category Modelling
[2018-05-28 18:28:50,443] log.py->debug():112 -- DEBUG -- showing task Macro modelling
[2018-05-28 18:28:50,477] log.py->message():133 -- MESSAGE -- Loading theme
[2018-05-28 18:28:50,480] log.py->message():133 -- MESSAGE -- Theme makehuman version 1.1.0
[2018-05-28 18:28:50,483] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2018-05-28 18:28:51,823] log.py->debug():112 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2018-05-28 18:28:51,865] log.py->message():133 -- MESSAGE -- Applying targets
[2018-05-28 18:28:51,979] log.py->debug():112 -- DEBUG -- Updating skeleton joint positions
[2018-05-28 18:28:52,029] log.py->debug():112 -- DEBUG -- Done baking animations
[2018-05-28 18:28:52,092] log.py->message():133 -- MESSAGE -- Loading macro targets
[2018-05-28 18:28:53,834] log.py->message():133 -- MESSAGE -- Loading done
[2018-05-28 18:28:54,000] log.py->debug():112 -- DEBUG -- Creating new texture for dynamic image data/litspheres/adaptive_skin_tone.png.
[2018-05-28 18:28:54,000] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-05-28 18:28:54,000] log.py->debug():112 -- DEBUG -- Creating new texture for image D:/Programme/makehuman-1.1.1-win32/data/litspheres/skinmat_eye.png.
[2018-05-28 18:28:54,009] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-05-28 18:28:54,009] log.py->debug():112 -- DEBUG -- Creating new texture for image D:/Programme/makehuman-1.1.1-win32/data/eyes/materials/brown_eye.png.
[2018-05-28 18:28:54,075] log.py->debug():112 -- DEBUG -- initTexture: 1024, 1024, False
[2018-05-28 18:32:16,364] log.py->debug():112 -- DEBUG -- hiding task Macro modelling
[2018-05-28 18:32:16,369] log.py->debug():112 -- DEBUG -- showing task Custom
[2018-05-28 18:32:22,559] log.py->debug():112 -- DEBUG -- Updating skeleton joint positions
[2018-05-28 18:32:22,608] log.py->debug():112 -- DEBUG -- Done baking animations
[2018-05-28 18:33:03,829] log.py->debug():112 -- DEBUG -- hiding task Custom
[2018-05-28 18:33:03,829] log.py->debug():112 -- DEBUG -- showing task Macro modelling
[2018-05-28 18:33:06,249] log.py->debug():112 -- DEBUG -- hiding task Macro modelling
[2018-05-28 18:33:06,250] log.py->debug():112 -- DEBUG -- showing task Gender
[2018-05-28 18:33:11,470] log.py->debug():112 -- DEBUG -- hiding task Gender
[2018-05-28 18:33:11,470] log.py->debug():112 -- DEBUG -- showing task Face
[2018-05-28 18:33:21,207] log.py->debug():112 -- DEBUG -- hiding task Face
[2018-05-28 18:33:21,209] log.py->debug():112 -- DEBUG -- showing task Torso
[2018-05-28 18:33:24,990] log.py->debug():112 -- DEBUG -- hiding task Torso
[2018-05-28 18:33:24,990] log.py->debug():112 -- DEBUG -- showing task Arms and Legs
[2018-05-28 18:33:25,809] log.py->debug():112 -- DEBUG -- hiding task Arms and Legs
[2018-05-28 18:33:25,809] log.py->debug():112 -- DEBUG -- showing task Random
[2018-05-28 18:33:27,490] log.py->debug():112 -- DEBUG -- hiding task Random
[2018-05-28 18:33:27,490] log.py->debug():112 -- DEBUG -- showing task Custom
[2018-05-28 18:33:28,130] log.py->debug():112 -- DEBUG -- hiding task Custom
[2018-05-28 18:33:28,130] log.py->debug():112 -- DEBUG -- showing task Random
[2018-05-28 18:34:40,194] log.py->debug():112 -- DEBUG -- hiding task Random
[2018-05-28 18:34:40,194] log.py->debug():112 -- DEBUG -- showing task Macro modelling
[2018-05-28 18:34:41,970] log.py->debug():112 -- DEBUG -- hiding task Macro modelling
[2018-05-28 18:34:41,970] log.py->debug():112 -- DEBUG -- showing task Gender
[2018-05-28 18:34:42,911] log.py->debug():112 -- DEBUG -- hiding task Gender
[2018-05-28 18:34:42,911] log.py->debug():112 -- DEBUG -- showing task Face
[2018-05-28 18:34:45,440] log.py->debug():112 -- DEBUG -- hiding task Face
[2018-05-28 18:34:45,440] log.py->debug():112 -- DEBUG -- showing task Torso
[2018-05-28 18:34:46,321] log.py->debug():112 -- DEBUG -- hiding task Torso
[2018-05-28 18:34:46,321] log.py->debug():112 -- DEBUG -- showing task Arms and Legs
[2018-05-28 18:34:47,490] log.py->debug():112 -- DEBUG -- hiding category Modelling
[2018-05-28 18:34:47,500] log.py->debug():112 -- DEBUG -- showing category Geometries
[2018-05-28 18:34:47,500] log.py->debug():112 -- DEBUG -- hiding task Arms and Legs
[2018-05-28 18:34:47,500] log.py->debug():112 -- DEBUG -- showing task Clothes
[2018-05-28 18:34:50,601] log.py->debug():112 -- DEBUG -- hiding category Geometries
[2018-05-28 18:34:50,601] log.py->debug():112 -- DEBUG -- showing category Modelling
[2018-05-28 18:34:50,602] log.py->debug():112 -- DEBUG -- hiding task Clothes
[2018-05-28 18:34:50,604] log.py->debug():112 -- DEBUG -- showing task Arms and Legs
[2018-05-28 18:34:51,943] log.py->debug():112 -- DEBUG -- hiding task Arms and Legs
[2018-05-28 18:34:51,943] log.py->debug():112 -- DEBUG -- showing task Custom
[2018-05-28 18:34:54,545] log.py->debug():112 -- DEBUG -- hiding task Custom
[2018-05-28 18:34:54,546] log.py->debug():112 -- DEBUG -- showing task Gender
[2018-05-28 18:34:55,444] log.py->debug():112 -- DEBUG -- hiding task Gender
[2018-05-28 18:34:55,444] log.py->debug():112 -- DEBUG -- showing task Macro modelling
[2018-05-28 18:34:59,591] log.py->debug():112 -- DEBUG -- hiding task Macro modelling
[2018-05-28 18:34:59,591] log.py->debug():112 -- DEBUG -- showing task Gender
[2018-05-28 18:35:00,599] log.py->debug():112 -- DEBUG -- hiding task Gender
[2018-05-28 18:35:00,599] log.py->debug():112 -- DEBUG -- showing task Face
[2018-05-28 18:35:01,950] log.py->debug():112 -- DEBUG -- hiding task Face
[2018-05-28 18:35:01,950] log.py->debug():112 -- DEBUG -- showing task Torso
[2018-05-28 18:35:57,279] log.py->debug():112 -- DEBUG -- hiding task Torso
[2018-05-28 18:35:57,282] log.py->debug():112 -- DEBUG -- showing task Face
[2018-05-28 18:35:57,871] log.py->debug():112 -- DEBUG -- hiding task Face
[2018-05-28 18:35:57,871] log.py->debug():112 -- DEBUG -- showing task Torso
[2018-05-28 18:39:44,065] log.py->debug():112 -- DEBUG -- hiding category Modelling
[2018-05-28 18:39:44,075] log.py->debug():112 -- DEBUG -- showing category Utilities
[2018-05-28 18:39:44,075] log.py->debug():112 -- DEBUG -- hiding task Torso
[2018-05-28 18:39:44,075] log.py->debug():112 -- DEBUG -- showing task Logs
[2018-05-28 18:39:46,065] log.py->debug():112 -- DEBUG -- hiding category Utilities
[2018-05-28 18:39:46,065] log.py->debug():112 -- DEBUG -- showing category Help
[2018-05-28 18:39:46,065] log.py->debug():112 -- DEBUG -- hiding task Logs
[2018-05-28 18:39:46,065] log.py->debug():112 -- DEBUG -- showing task Help
[2018-05-28 18:39:53,338] log.py->debug():112 -- DEBUG -- hiding category Help
[2018-05-28 18:39:53,338] log.py->debug():112 -- DEBUG -- showing category Utilities
[2018-05-28 18:39:53,338] log.py->debug():112 -- DEBUG -- hiding task Help
[2018-05-28 18:39:53,338] log.py->debug():112 -- DEBUG -- showing task Logs
[2018-05-28 18:39:54,415] log.py->debug():112 -- DEBUG -- hiding category Utilities
[2018-05-28 18:39:54,415] log.py->debug():112 -- DEBUG -- showing category Settings
[2018-05-28 18:39:54,415] log.py->debug():112 -- DEBUG -- hiding task Logs
[2018-05-28 18:39:54,415] log.py->debug():112 -- DEBUG -- showing task General
[2018-05-28 18:39:55,026] log.py->debug():112 -- DEBUG -- hiding category Settings
gakusei_namuhekam
Postby Aranuvir » Tue Jul 03, 2018 9:28 pm
I do not really understand what we got here. These log do not look like an application, that crashed right after start up. At least the application was running from 18:28:46,059 to 18:42:55,171. The error messages are coming from plugins that get unloaded, when the application gets closed. And the time stamps seem to be inconsistent: what happened between 18:28:46,792 and 18:42:55,161?
An input output issue seems to be evident: IOError: [Errno 13] Permission denied: u'C:/Users/.../Documents/makehuman/v1/cache/eyelashes_filecache.mhc' . Apparently something is blocking the application to access the documents folder. Maybe you want to check all security tools that are installed on your computer, if any of them is blocking MakeHuman.
Have fun and good luck...
