I am pretty sure that it is a bug we already fixed, but did not roll out that new (already 3 year old) version. One asset contains a letter (entered in Blender as a "tag") which is not ignored.
(we really should do a new version. we fixed a lot of other errors in between)
This was the error, I fixed
https://github.com/makehumancommunity/m ... e50f24d2aaLast message here:
viewtopic.php?f=3&t=20000If there was no other file ... then there must be a file called Jacket01.mhclo. Take a text-editor (it is ASCII) replace that é with a normal e (not far away from top ... tags) .
I am not sure, but best to delete the mhpxy file with the same name then (it is a binary representation of that mhclo and loads faster.) ... I hope it works.
The real reason is: the system looks into cache/clothes_filecache.mhc in v1py3 folder. But the process creating this cache just fails .. so the cache-file is shorter, depending on when the process crashed. Afaik the cache is re-generated when an asset is changed, so maybe only throwing out that one letter will fix it without installing a new version (which is only available on github).
I will certainly do that different, I work on the new version. There is too much "information hiding" in old version and the reverse-engineering is all but not easy. If I really need to use sth as a filecache there will be a sqlite database, but it will always be possible to recreate that complete from scratch and errors should not disappear somewhere. To keep the file-system in sync with an own representation in some kind of cache could always create problems
Greets,
