Clothes2 in Blender
Clothes2 in Blender
Postby etienne.voice » Tue Oct 25, 2022 10:03 pm
I made a pair of cargo pants and exported with the MakeClothes2 plugin.
When I later import the .mhclo file the mesh has many seemingly random edges
I tried merging nearby vertices, but no vertices needed welding
This wouldn't necessarily be a problem, but when I go on to export as a .vrm character I get the strangest errors with the mesh seeming to breakup
Am I doing something wrong with the mesh or the material?
Any help most gratefully received. Thanks for reading
Baggy Cargo Pants_ImportedFromMH.blend
(7.93 MiB) Downloaded 271 times
BAggy Cargo Pants retop3500FacesOnCharacter5MakeClothesExported.blend
(25.34 MiB) Downloaded 271 times
etienne.voice
Re: Clothes2 in Blender
Postby Elvaerwyn » Tue Oct 25, 2022 10:39 pm
Greetings,
Nice pant! I'm sure whatever the issue is can be resolved, however I have no experience in vrm characters. That said it is likely a small oversight in export from blender to makehuman that will resolve much if not all of the tearing you witness in the mesh. Out of curiousity what vertices on the helper were used on export?
If not already assigned, I would try to assign the pant to only a pant vertex group for export -that will align with the legs of the model or the legs of the tights helper mesh. This little bit of work is helpful on every export to be honest going forward, you may consider making a file called something like clothesdesign or similar and make all clothes in this same blender file in future, thus you can save all helper vertex groups to use on additional clothes you make.
Nice to see a budding clothing creator!
Elv
Postby etienne.voice » Tue Oct 25, 2022 11:12 pm
Thanks for taking a look at this and your kind words.
I tried to follow this excellent tutorial http://www.makehumancommunity.org/wiki/ ... tex-Groups
I've added a picture of the vertex groups I specified, the helper only had the vertex group 'trousers' assigned. Is that the approach you were suggesting?
etienne.voice
Postby Elvaerwyn » Wed Oct 26, 2022 1:31 am
Wonderful,
Yes this is the tutorial to go to for learning the vertex assignments! Out of curiosity, in the image you show, is the pant and tights used for vertex or the pant with body? Also is the body used soley for a delete group? If using tights helper, possibly try the same workflow but use the body group you selected as both the delete group(invisble body area), and the helper for your pants! Curious to see if the same is shown to be true.
Also I noticed this is a tri mesh, this is supported but in past has had mixed results for some, have you had the same issues by chance with soley quad meshes?
Elv
Return to Blender and MPFB
