Problem in hair rendering
Postby ivmeneze » Sat Feb 17, 2018 5:25 pm
I have used Daz hair models in my Makehuman characters, but on some models a rendering problem has arisen. A kind of shadow, how to solve?
ivmeneze
Re: Problem in hair rendering
Postby loki1950 » Sat Feb 17, 2018 7:32 pm
Have you played with the fac value on the mix shader if that does not alleviate the problem then a closer look at the texture will be in order as there may be a mapping issue.
Postby ivmeneze » Sat Feb 17, 2018 7:46 pm
loki1950 wrote:Have you played with the fac value on the mix shader if that does not alleviate the problem then a closer look at the texture will be in order as there may be a mapping issue.
Do you want to try?
ivmeneze
Postby Aranuvir » Sat Feb 17, 2018 8:50 pm
I'm not sure if this DAZ content is free to share. If not, please remove the files!
Postby wolgade » Sat Feb 17, 2018 10:27 pm
Looks like a problem with transparency. DAZ uses JPEG which doesn't support an alpha channel. Have a look at the texture controlling transparency. Insert a color ramp there and try to fix it by adjusting the color ramp
Postby ivmeneze » Sat Feb 17, 2018 11:16 pm
wolgade wrote:Looks like a problem with transparency. DAZ uses JPEG which doesn't support an alpha channel. Have a look at the texture controlling transparency. Insert a color ramp there and try to fix it by adjusting the color ramp
Thank you!
I managed to change the transparency in the Render tab...
ivmeneze
