Using M.H. to control a text-to-image AI
Postby green_tomato » Sat Jul 08, 2023 10:44 am
It's possible to use MakeHuman to control Stable Diffusion using ControlNet's "depth" mode by rendering out the depth buffer (or "Z buffer" as the depth information is often called) using Blender or a similar tool.
This will produce an image where objects that are close will be white, and areas that are far away are dark.
Then you can use the AI's usual tools to control the style. Here are some examples:
green_tomato
Re: Using M.H. to control a text-to-image AI
Postby joepal » Sat Jul 08, 2023 10:52 am
That's actually pretty interesting.
I hadn't thought of using MH as input data for AI.
Postby joepal » Sat Jul 08, 2023 11:40 am
Approximation of the same idea in blender: Create a "camera distance material"
Postby green_tomato » Sat Jul 08, 2023 12:02 pm
Oh neat trick. I just used the compositor section to output the "Depth" layer, like this:
green_tomato
