wolgade wrote:Blondes are challenging. What I did: I changed the color of the hair along the strands.
This bakes the question: Why should blonde hair change it's properties along the strands. Is this physically correct? Some change along the strand could be explained by environmental influences. The closer to the tip parts have been exposed to them longer than those close to the root.
But this is quite an abrupt change in color. Why does this look convincing? The answer is in my opinion that a lot of blonde women are not so by nature. We're so used to these fake blondes and how they look, that we expect darker hair roots. It's a bit the same story as with strawberry youghurt, where the flavour comes from anything but strawberries. You're so used to this artificial stuff that you are disappointed when you get to taste the real thing.
Okay, thanx a lot. You use a wooden texture to influence it, somewhere I've seen that before
. Well I do the color change also for my Dani model (Leska as well). For Dani it does not work, it is visible but does not look convincing. I will try your setup and will present the result (if I like it). For my Dani-model I had pictures with nearly golden hair and also something between grey and green and white, so it depends from the light setup of the photographer.
I googled a little and got the following answer: Natural hair color change is done by oxidation (UV light) & humidity (rain, sweat), the color could reach a range from middle to light blond. It also works for other colors, but it is not visible in the same form, pheomelanin (blond, red hair) seems to react in another way than eumelanin (black, brown hair).
But you are right. It is common to "help the nature" a bit ... like only coloring highlights
https://en.wikipedia.org/wiki/File:Straight_hair_with_highlights.jpg. In this case it does look rather natural and not like platinum blonde.
For strawberry yogurt (or yoghurt or yoghourt ... just looked into leo.org ... we got this word from the Turks btw.
) I buy strawberries and a natural yogurt. Best in summer of course ...
