The newest version
Re: The newest version
Postby joepal » Thu Dec 26, 2019 5:25 pm
This is a very interesting bug report. Thank you for the log.
It is related to the graphics card, although I am not sure it is the same problem as earlier nor what causes it
I'm abroad until next week and won't be able to look at it further until I'm back. But I doubt you will be able to solve this by tweaking graphics card settings or drivers. It will probably require a code change to handle.
Postby joepal » Wed Jan 01, 2020 4:05 pm
Do you happen to have a laptop with two graphics cards? The one in the screenshot is the intel one bundled with the CPU, but many laptops also have an "accelerated" mode where applications can be run on a different chipset.
Reason I ask is because the error message usually turns up as something similar.
Postby azajali43 » Thu Mar 12, 2020 2:40 pm
You can clear your unwanted or not in use data in your laptop, And then you can install the new version. The problem might be get fix.
azajali43
