The newest version
The newest version
Postby ronisegoly » Tue Dec 24, 2019 12:55 pm
What''s the last stable version of makehuman? I tried installing 1.2 but it crashes my laptop when I tried open the zip file
ronisegoly
Re: The newest version
Postby loki1950 » Tue Dec 24, 2019 5:07 pm
Have look at our wiki the Docs & FAC link on our header the look for Releases 120a4 for the full notes also the latest version uses a Windows installer not a zip file.
Postby joepal » Tue Dec 24, 2019 6:13 pm
Did you try running from *inside* the zip file? That wont work. You need to extract all files to somewhere on your computer first, for exemple to the desktop. Then you can run the installer from there.
Postby ronisegoly » Tue Dec 24, 2019 11:32 pm
Can you please send the link to Windows installer of 120a4
Thanks
ronisegoly
Postby loki1950 » Wed Dec 25, 2019 12:28 am
Here is download link from the wiki page http://download.tuxfamily.org/makehuman ... -win32.zip and as Joel said do not open it right click and choose "extract" then run the installer from the extracted zip folder here's a link to the release notes on the wiki it also has the download link which is why I pointed it out to you in my answer in the first place http://www.makehumancommunity.org/wiki/Releases:120a4
Postby ronisegoly » Wed Dec 25, 2019 6:34 am
I am not sure what's the issue with my laptop, I tried downloading, it takes long time, and then file explorer hangs or becomes very slow, when I try to extract or even copy the files from the zip file
I finally managed to extract and install, but now I get the logo, and again loading the files on startup is very slow, and then I get exception error.
I manged smoothly to install on my other laptop
ronisegoly
Postby loki1950 » Wed Dec 25, 2019 4:36 pm
Sounds like your hard drive might be getting a bit full as it seems to be not finding enough space for the temporary files during extraction so do you see the disk activity light or have the task monitor running.Now lets debug that exception could you post the log file from MH you can find it in the makehuman\v1py3 folder in My Documents that should tell us exactly what is causing the issue.
Postby ronisegoly » Wed Dec 25, 2019 4:54 pm
Hard disk is not full, plenty of space but I assume there is an issue
I added two attachments
makehuman-debug.txt
(3 KiB) Downloaded 594 times
makehuman.log
(9.37 KiB) Downloaded 586 times
ronisegoly
Postby loki1950 » Wed Dec 25, 2019 6:32 pm
Looks to be an OpenGL issue does this laptop use an Intel GPU if so try adding --noshaders to the shortcut that starts the app or find newer driver for the graphic system if one is available. This is how to do that just right-click on the desktop shortcut and select "Properties" then follow this guide http://www.makehumancommunity.org/wiki/ ... help_me%3F if that does not work may have to wait till one of the devs chimes in as I'm not fully familiar with the code.
Postby ronisegoly » Thu Dec 26, 2019 10:08 am
I am not sure about graphic card, attaching report by a tool I downloaded
Running MH with the proposed parameters did not solve the problem
ronisegoly
