Adding Asset packs, instructions are outdated
Postby aurochs » Sun Nov 16, 2025 9:13 pm
The Docs say the MPFB Extension is the recommended way to use Makehuman but the asset pack instructions show the standalone app.
I'm assuming it involves the Blender Preferences, where I see a line for path to MPFB user data but there's no button to select the path.
If I'm supposed to manually type a path, there's no instruction for what the format should be.
Using Blender 4.5 on Mac OS 15.4
aurochs
Re: Adding Asset packs, instructions are outdated
Postby aurochs » Sun Nov 16, 2025 9:29 pm
I found what I needed in the Getting Started section. I was looking here and couldn't figure out what to do:
https://static.makehumancommunity.org/a ... ssets.html
This should probably be clarified
aurochs
Postby tomcat » Mon Nov 17, 2025 3:37 pm
aurochs wrote:If I'm supposed to manually type a path, there's no instruction for what the format should be.
This is only about Windows, if that helps.
viewtopic.php?f=22&t=24313
