MH version set to 1.2.0 on github
Postby joepal » Wed Nov 07, 2018 9:26 am
As we're preparing to release a first alpha of the updated code, the version of makehuman has now been set to 1.2.0 on github.
Together with some changes in metadata, this means that MHM files saved from the github version will no longer be possible to open in MH 1.1.1. The other way is unaffected: old MHM files can be opened unchanged in 1.2.0 since there is an automatic compatibility filter for these.
Note that this only concerns MHM files (i.e toons saved from within makehuman). All other files have exactly the same file format as 1.1.1, and all assets produced for 1.1.x will still work in 1.2.0.
Re: MH version set to 1.2.0 on github
Postby Aranuvir » Wed Nov 07, 2018 6:26 pm
And if someone wants to use a mhm file with old versions of MakeHuman, just edit the version number in the mhm file to something like 1.1.1. We are still discussing a option in the save tab for old version.
