- Code: Select all
Loading plugins
Importing plugin 0_modeling_0_modifiers
Imported plugin 0_modeling_0_modifiers
Loading plugin 0_modeling_0_modifiers
Loading modifiers from data/modifiers/modeling_modifiers.json
Attempting to load targets from NPZ file.
1258 targets loaded from NPZ file succesfully.
Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
Loaded plugin 0_modeling_0_modifiers
Importing plugin 0_modeling_8_random
Imported plugin 0_modeling_8_random
Loading plugin 0_modeling_8_random
Loaded plugin 0_modeling_8_random
Importing plugin 0_modeling_9_custom_targets
Imported plugin 0_modeling_9_custom_targets
Loading plugin 0_modeling_9_custom_targets
Loaded plugin 0_modeling_9_custom_targets
Importing plugin 0_modeling_a_measurement
Imported plugin 0_modeling_a_measurement
Loading plugin 0_modeling_a_measurement
Loading modifiers from data/modifiers/measurement_modifiers.json
Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
Loaded plugin 0_modeling_a_measurement
Importing plugin 0_modeling_background
Imported plugin 0_modeling_background
Loading plugin 0_modeling_background
Loaded plugin 0_modeling_background
Importing plugin 2_foot_posing
Imported plugin 2_foot_posing
Loading plugin 2_foot_posing
Loaded plugin 2_foot_posing
Importing plugin 2_posing_expression
Imported plugin 2_posing_expression
Loading plugin 2_posing_expression
Loaded plugin 2_posing_expression
Importing plugin 3_libraries_animation
Imported plugin 3_libraries_animation
Loading plugin 3_libraries_animation
Loaded plugin 3_libraries_animation
Importing plugin 3_libraries_clothes_chooser
Imported plugin 3_libraries_clothes_chooser
Loading plugin 3_libraries_clothes_chooser
Loaded plugin 3_libraries_clothes_chooser
Importing plugin 3_libraries_eye_chooser
Imported plugin 3_libraries_eye_chooser
Loading plugin 3_libraries_eye_chooser
Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
compiled proxy file missing: data/eyes/high-poly/high-poly.mhpxy
Problem loading binary proxy: ('compiled proxy file missing: %s', u'data/eyes/high-poly/high-poly.mhpxy')
Loading proxy file: data/eyes/high-poly/high-poly.mhclo.
Loading material from file /usr/share/makehuman/data/eyes/materials/brown.mhmat
Shader: adding built-in uniform gl_NormalMatrix
Shader: adding built-in uniform gl_ModelViewProjectionMatrix
VectorUniform(AdditiveShading) = [ 0.]
Not writing compiled proxies to system paths (data/eyes/high-poly/high-poly.mhpxy).
Loading binary mesh /usr/share/makehuman/data/eyes/high-poly/high-poly.npz.
Loaded plugin 3_libraries_eye_chooser
Importing plugin 3_libraries_eyebrows
Imported plugin 3_libraries_eyebrows
Loading plugin 3_libraries_eyebrows
Loaded plugin 3_libraries_eyebrows
Importing plugin 3_libraries_eyelashes
Imported plugin 3_libraries_eyelashes
Loading plugin 3_libraries_eyelashes
Loaded plugin 3_libraries_eyelashes
Importing plugin 3_libraries_material_chooser
Imported plugin 3_libraries_material_chooser
Loading plugin 3_libraries_material_chooser
Loaded plugin 3_libraries_material_chooser
Importing plugin 3_libraries_polygon_hair_chooser
Imported plugin 3_libraries_polygon_hair_chooser
Loading plugin 3_libraries_polygon_hair_chooser
Loaded plugin 3_libraries_polygon_hair_chooser
Importing plugin 3_libraries_pose
Imported plugin 3_libraries_pose
Loading plugin 3_libraries_pose
Loaded plugin 3_libraries_pose
Importing plugin 3_libraries_proxy_chooser
Imported plugin 3_libraries_proxy_chooser
Loading plugin 3_libraries_proxy_chooser
Loaded plugin 3_libraries_proxy_chooser
Importing plugin 3_libraries_skeleton
Imported plugin 3_libraries_skeleton
Loading plugin 3_libraries_skeleton
Loaded plugin 3_libraries_skeleton
Importing plugin 3_libraries_teeth
Imported plugin 3_libraries_teeth
Loading plugin 3_libraries_teeth
Loaded plugin 3_libraries_teeth
Importing plugin 3_libraries_tongue
Imported plugin 3_libraries_tongue
Loading plugin 3_libraries_tongue
Loaded plugin 3_libraries_tongue
Importing plugin 4_rendering_9_viewer
Imported plugin 4_rendering_9_viewer
Loading plugin 4_rendering_9_viewer
Loaded plugin 4_rendering_9_viewer
Importing plugin 4_rendering_opengl
Imported plugin 4_rendering_opengl
Loading plugin 4_rendering_opengl
Assigning setting rendering_width value 800 that was loaded before the setting was declared.
Assigning setting rendering_height value 600 that was loaded before the setting was declared.
Assigning setting GL_RENDERER_SSS value False that was loaded before the setting was declared.
Assigning setting GL_RENDERER_AA value True that was loaded before the setting was declared.
Loaded plugin 4_rendering_opengl
Importing plugin 4_rendering_scene
Imported plugin 4_rendering_scene
Loading plugin 4_rendering_scene
Setting rendering_width is already declared. Adding it again has no effect.
Setting rendering_height is already declared. Adding it again has no effect.
Loaded plugin 4_rendering_scene
Importing plugin 5_settings_0_settings
Imported plugin 5_settings_0_settings
Loading plugin 5_settings_0_settings
Setting language to english
Theme makehuman version 1.1.0
Loaded theme data/themes/makehuman.mht
Loaded Qt style data/themes/makehuman.qss
Loaded plugin 5_settings_0_settings
Importing plugin 5_settings_mouse
Imported plugin 5_settings_mouse
Loading plugin 5_settings_mouse
Loaded plugin 5_settings_mouse
Importing plugin 5_settings_shortcuts
Imported plugin 5_settings_shortcuts
Loading plugin 5_settings_shortcuts
Loaded plugin 5_settings_shortcuts
Importing plugin 6_help
Imported plugin 6_help
Loading plugin 6_help
Loaded plugin 6_help
Importing plugin 7_expression_mixer
Imported plugin 7_expression_mixer
Loading plugin 7_expression_mixer
Loaded plugin 7_expression_mixer
Importing plugin 7_logging
Imported plugin 7_logging
Loading plugin 7_logging
Loaded plugin 7_logging
Importing plugin 9_export_bvh
Imported plugin 9_export_bvh
Loading plugin 9_export_bvh
Loaded plugin 9_export_bvh
Importing plugin 9_export_collada
Imported plugin 9_export_collada
Loading plugin 9_export_collada
Loaded plugin 9_export_collada
Importing plugin 9_export_fbx
Imported plugin 9_export_fbx
Loading plugin 9_export_fbx
Loaded plugin 9_export_fbx
Importing plugin 9_export_light
Imported plugin 9_export_light
Loading plugin 9_export_light
Loaded plugin 9_export_light
Importing plugin 9_export_obj
Imported plugin 9_export_obj
Loading plugin 9_export_obj
Loaded plugin 9_export_obj
Importing plugin 9_export_ogre
Imported plugin 9_export_ogre
Loading plugin 9_export_ogre
Loaded plugin 9_export_ogre
Importing plugin 9_export_stl
Imported plugin 9_export_stl
Loading plugin 9_export_stl
Loaded plugin 9_export_stl
Importing plugin 9_export_uvmap
Imported plugin 9_export_uvmap
Loading plugin 9_export_uvmap
Loaded plugin 9_export_uvmap
Loading GUI
showing category Modelling
showing task Macro modelling
Loading theme
Applying targets
Updating skeleton joint positions
Done baking animations
Loading macro targets
Loading done
But no 9_export_mhx2
Did the user plugin path change or the plugin format? Is there any way to get it working?
