Make Target Standalone
Postby formerbusinessowner » Tue Mar 20, 2018 11:54 am
I've been trying to install Make Target Standalone but can't figure it out
I've pip installed all the necessary components in python, as far as I can tell, but none of the .py or batch files in the make target standalone folder seem to work to actually install the gui
Any direction would be greatly appreciated
formerbusinessowner
Re: Make Target Standalone
Postby RobBaer » Tue Mar 20, 2018 12:26 pm
Having never tried to use the stand-alone MakeTarget, I probably shouldn't be answering you.
That said, I will direct you toward the readme.txt file in that directory which has some instructions for the command line version of the stand alone that might be helpful if you have not already looked at them. The command line version seems geared toward batch processing targets. The status of the GUI standalone is even more uncertain, but there is always the Blender plugin.
