how to export all expressions at once ? PLEASE HELP
Postby danFFFX » Sat Feb 10, 2018 1:44 pm
if i've a character that i made but i need to export all the facial expressions not one by one but all the expressions at once is there a script to use in order to get a working result ? PLEASE HELP
danFFFX
Re: how to export all expressions at once ? PLEASE HELP
Postby joepal » Sat Feb 10, 2018 1:51 pm
If all you want to do is use expressions in blender, you can use MHX2. It has an expression panel allowing you to set an expression in blender rather than at export.
If you need to export to somewhere else, you'd have to write a script to achieve this, which would not be trivial if you don't already have some experience with MH coding.
Postby danFFFX » Sat Feb 10, 2018 2:10 pm
i export from makehuman to maya and i don't know how to write a python code , i need a code to use it to export all expressions at once instead of manually export more than 50 expressions i expoer them as .obj , thanks for your help
danFFFX
Postby Deacon2099 » Tue Mar 06, 2018 12:17 pm
Hello,
I have the same problem. I'm importing to Blender. Can you give a link to a solution that will allow to export to Blender more than only one face expression or body position?
Deacon2099
