asset downloader refactor text missing
Postby badwolf » Tue Dec 05, 2017 2:46 pm
as part of a recent upgrade to a newer computer i installed a copy of MakeHuman and setup the asset downloader refactor from fresh downloads. When i try to use it the text in the list of assets is missing i get the grid but no text (it works otherwise) what could be going on since there is nothing in the MH log
badwolf
Re: asset downloader refactor text missing
Postby joepal » Tue Dec 05, 2017 5:36 pm
If you want to start from scratch, delete the makehuman/v1/data/community-assets directory (in your home dir) and reopen MH. This dir only contains settings and local cache for the asset downloader, so you don't lose anything important by deleting it.
Postby badwolf » Thu Dec 07, 2017 3:00 pm
joepal wrote:If you want to start from scratch, delete the makehuman/v1/data/community-assets directory (in your home dir) and reopen MH. This dir only contains settings and local cache for the asset downloader, so you don't lose anything important by deleting it.
which tells me nothing about how to actually FIX THE ISSUE
everything works properly except the text display in the asset downloader (which is the refactor version)
badwolf
Postby joepal » Thu Dec 07, 2017 4:19 pm
Can you post a screenshot?
Postby badwolf » Sun Dec 10, 2017 7:32 pm
joepal wrote:Can you post a screenshot?
https://www.dropbox.com/s/ho0g4kzlf2v1y ... 9.png?dl=0
badwolf
Postby joepal » Mon Dec 11, 2017 9:36 am
Ok. I have no idea why this happens, I've never seen it before. If there had been a crash, it would have appeared in the MH log.
It is possible to enable more detailed logging in the downloader plugin by setting the environment variable "assetdownload" to "4" before starting MH (for how to do this in windows, see https://www.computerhope.com/issues/ch000549.htm).
Having done so, you should be getting a new directory (makehuman/v1/plugin_logs/) with more logs, specifically a log file called "assetdownload.txt".
If I can get this file, I could start looking for an answer.
Postby joepal » Mon Dec 11, 2017 9:39 am
Another question: Do the drop down fields contain any selectable values?
Also, can you attach the JSON files found in the makehuman/v1/data/community-assets directory? There should be two or three, probably named "local.json" and "remote.json".
Postby badwolf » Mon Dec 11, 2017 3:07 pm
joepal wrote:Another question: Do the drop down fields contain any selectable values?
the drop downs work correctly btw could it be a python 3 problem??
https://www.dropbox.com/s/ds4mewmay7tv6 ... s.zip?dl=0
badwolf
Postby Aranuvir » Mon Dec 11, 2017 3:20 pm
badwolf wrote:[
I fear that could be the case. I had made some changes recently, so it works on system and forgot it should be P2 compatible, too. Best solution would be reverting my latest commit and make a separate P3 branch.
Postby joepal » Mon Dec 11, 2017 4:27 pm
To be clear: Which version of MH and which version of the downloader are you using?
I have done minimal testing of the asset downloader together with the python 3 version of MH. If there's a problem with it, then that is important information.
